How Much Oil Does My Bike Take? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 7 (permalink) Old 07-22-2008, 10:42 AM Thread Starter
I am trying to find how much oil should be put in my bike and what type i should use i have just bought a 2000 Yamaha V-Star 1100 with 8,000 miles on it and i have no owner's manual can you folks help me out Thanks, Toole
DTOOLE55 is offline
post #2 of 7 (permalink) Old 07-23-2008, 04:49 PM
adjunct moderator
indianaroadracer's Avatar
Yamaha always used to put the oil quantity in cc's near the filler hole but the best way is to simply check the oil using the sight glass. Have 4 quarts of oil and fill till you hit the top line in the sight glass while holding the bike straight up and down. Recheck oil after running for a few seconds when replacing your oil filter too.
indianaroadracer is offline
post #3 of 7 (permalink) Old 07-23-2008, 09:46 PM
Back _Marker's Avatar
is there an oil site glass on the engine case?
post #4 of 7 (permalink) Old 07-24-2008, 05:37 AM
sometimes that info is written under a seat or a side panel, I would think it takes more than 4 quarts, my 600 takes almost 5.
TXEMT is offline
post #5 of 7 (permalink) Old 08-19-2008, 02:07 PM
Everyday Riding & General Discussion
Hi
This is alexhopes , i used to ride my honda bike every day.It has good look and it gives nearly 75 kilometers per liter.I feel comfortble on my bike.when i sit.
alexhopes
Michigan Drug Treatment
alexhopes is offline
post #6 of 7 (permalink) Old 08-20-2008, 06:32 PM
Newbie
I have an 02, 1100 V-Star Classis.
It will hold 4 qts if you change the oild filter, and approx 3.5 qts if you do not change the oil filter. If it has the factory exhaust system on it, it has to come off. If you have an after market, the front pipe has to come off to get to all the bolts that holds the cover on over the filter.
This applies to the 1100 V-Stars and hope it helps.
hayabusa1 is offline
post #7 of 7 (permalink) Old 08-20-2008, 06:40 PM
Newbie
I have always used MobilOne Delvac 15W-40. About 9-11.00 a gallon. I have 33,000 trouble free miles. (This is just my 2 cents worth, and am not trying to start an oil war, just my answers the this members question.)
Human Verification
