Should I *need* to choke my bike to start it? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 17 (permalink) Old 11-03-2004, 07:29 AM Thread Starter
Seems lately my bike won't even start unless it's choked. The last time this happened, the carbs were clogged and it cost me over $200 to get 'em cleaned.
I know my air filter is clogged, but would that cause rough starting?
post #2 of 17 (permalink) Old 11-03-2004, 09:38 AM
A TWF Original
Need4Speed's Avatar
Send a message via AIM to Need4Speed Send a message via MSN to Need4Speed Send a message via Yahoo to Need4Speed
u know I had just had this problem, and it cost me 250.00 to get the carbs cleaned, among a couple other things. BUt with my kat, you nearly always have to choke it, about 1/4 of the way to get her to fire up if its even the slightest bit cold outside. Since that maint, its been 100% better than it was b/4..i still have to choke, but she warms up ALOT quicker now.
I won't tell, but you just got passed by a Kat !!!
Matt - 750 Kat Rider, & TWF Original PostWhore
Need4Speed is offline
post #3 of 17 (permalink) Old 11-03-2004, 12:35 PM
No Worries's Avatar
I cleaned out everything in the float chamber of my carbs and it was still hard to start. The choke, or as Honda calls it the bystarter valve, had to be cleaned. The problem is that each valve faces another carb, so they had to be completely dismanteled from each other. I think there were 36 phillips-head screws holding the carbs together, and each wanted to strip their head.
After lots of cusing, impact wrenching, and vice grips on two screws, I got them apart. I cleaned out 14 years of crud in the bystarter valve, without mixing up any parts. $250 would have been cheap for what took me two whole days. Starts right up now, using the choke when cold. I never use the choke when the engine is warm.
post #4 of 17 (permalink) Old 11-03-2004, 12:46 PM Thread Starter
I'd gladly pay to NOT have to go through that.
post #5 of 17 (permalink) Old 11-03-2004, 02:00 PM
A TWF Original
Need4Speed's Avatar
yeah, even if I did know what I was doing with my carbs, that is WAY to much hassle to go thru. I'll let the dealer mess with it.
post #6 of 17 (permalink) Old 11-03-2004, 02:19 PM
Yes you need a choke...and yep, your carbs need to be cleaned...just do it over the winter...
Even FI bikes/cars have their own style of a choke. That's why they also idle up when you start them...
post #7 of 17 (permalink) Old 11-03-2004, 09:58 PM
A bike that doesn't need the choke (actually an enrichener) is probably too rich. However, you should only need it to get the bike to fire and run for a couple of minutes. I don't like to use the choke for the high-idle to warm up it up to operating temperature. I prefer to turn off the choke as soon as the bike will accept light throttle and maintain an idle.
post #8 of 17 (permalink) Old 11-03-2004, 10:00 PM
Yeah, that's what I said! You need a choke to fire er up! ROCK ON LARRY!!!
post #9 of 17 (permalink) Old 11-04-2004, 12:21 PM
twisty's Avatar
UUUMMM my gixxer doent have choke.....:0
post #10 of 17 (permalink) Old 11-04-2004, 01:25 PM
It does have a built in FI choke....when you first start it the FI is in a closed loop until it gets warm enough then the FI goes open loop... FI Choke!
post #11 of 17 (permalink) Old 11-04-2004, 01:28 PM
twisty's Avatar
wrong!!!!!
post #12 of 17 (permalink) Old 11-04-2004, 01:33 PM
twisty's Avatar
Suzuki moved away for the FI closed loop choke. They now have their patterned Suzuki Emissions sensor array. Works kinda like the closed loop but it monitors the exhaust gas temp to adjust the engine ittle. It is pretty interesting. The guy at the Suzuki dealer was telling me about it.
post #13 of 17 (permalink) Old 11-04-2004, 01:46 PM
In general it's the same...the only difference is where the computer is picking up it's temp readings.....the outcome is all the same!
post #14 of 17 (permalink) Old 11-05-2004, 07:45 AM
twisty's Avatar
UUUMMM yeah. It is not the same tho. Its more advanced....lol
post #15 of 17 (permalink) Old 11-05-2004, 09:31 AM
Mojo's Avatar
It's all those fancy left-handed screwdrivers they use in production. They're much more technologically advanced!!
'00.5 Aprilia Mille R
http://www.fresnomotorsports.com
Mojo is offline
post #16 of 17 (permalink) Old 11-05-2004, 12:28 PM
Good one Mojo! I'm sure it's nice and advanced but it does the same thing....
I'm not trying to debate the advancement of the Suz just that FI also has it's own type of choke...
post #17 of 17 (permalink) Old 11-11-2004, 01:39 PM
Captain Morgan's Avatar
It really depends on the weather. Also, have you ALWAYS had to choke the bike, or is this recent. If it's recent, and it's not getting cold outside where you live, then you may need to have some work done.
Surrender the booty, and let me get my hands on that beautiful treasure chest!!
One of these days, I'll actually buy a bike again...
Human Verification
