Can someone explain a "false neutral"? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 11 (permalink) Old 12-13-2004, 12:40 PM Thread Starter
I know what it is, I hit it on my bike from time to time. I'm wondering how it happens and what I can do to keep it from happening?
post #2 of 11 (permalink) Old 12-13-2004, 12:45 PM
twisty's Avatar
It sucks....
post #3 of 11 (permalink) Old 12-13-2004, 12:48 PM
GSXR1000DJ's Avatar
Send a message via AIM to GSXR1000DJ Send a message via Yahoo to GSXR1000DJ
Great way to explain it to all of us Twisty.
Dave~~~TWF Moderator
"Post Up or Shut Up"
Speed doesn't kill...It makes you feel alive.
03 GSXR 1000
GSXR1000DJ is offline
post #4 of 11 (permalink) Old 12-13-2004, 12:53 PM Thread Starter
It's all so clear now.
post #5 of 11 (permalink) Old 12-13-2004, 06:13 PM
SpeedWerks.com's Avatar
A false neutral can be caused by a lot of different things. Mechanical reasons, from worn gears to a bent shift fork to poorly adjusted shift linkage to just rider error (not a positive enough shift). There are a number of reasons that can cause a false neutral.
If it's mechanical, it's usually worn gears or a bent shift fork.
If you're not on a SpeedWerks bike, you're probably behind one!
SpeedWerks Online Store
SpeedWerks Sportbike Services
SpeedWerks.com is offline
post #6 of 11 (permalink) Old 12-13-2004, 06:29 PM
A TWF Original
Need4Speed's Avatar
Send a message via AIM to Need4Speed Send a message via MSN to Need4Speed Send a message via Yahoo to Need4Speed
thats better..thanks !!
im sure twisty knew that..but well, u know, its twisty
I won't tell, but you just got passed by a Kat !!!
Matt - 750 Kat Rider, & TWF Original PostWhore
Need4Speed is offline
post #7 of 11 (permalink) Old 12-13-2004, 08:37 PM
No Worries's Avatar
I always assumed that a false neutral is when you hit a neutral between a gear that's not first and second. I've never had that, but I have hit real neutral when accelerating hard and shifting from first and getting neutral instead of second. The worst part is at the next light, telling the other rider "Oh, I meant to do that."
post #8 of 11 (permalink) Old 12-13-2004, 09:11 PM
A false neutral (as in not between 1st and 2nd) is caused by the dogs and slots not engaging enough to provide drive. As speedwerks mentioned, there can be several reasons why they won't engage. If nothing is bent and it is a matter of the shift drum not rotating enough (from your limp foot), you can try a shift kit which helps rotate the shift drum with a little more force.
post #9 of 11 (permalink) Old 12-14-2004, 09:44 AM
July 2006 BOTM Winner!
Pippi's Avatar
Send a message via Yahoo to Pippi
Yep, been there done that!
"I am the Voice of the Voiceless" http://tinyurl.com/y556pq www.resq4paws.org
Pippi is offline
post #10 of 11 (permalink) Old 12-14-2004, 05:12 PM
hondaguy's Avatar
I hate hitting a false nuetral...it doesnt happen often, but when it does its usually when I "lazy shift" or when I try and actually shift too fast when Im riding hard. I always look around to see if anybody noticed.
- Greg -
Honda CBR 600F3
hondaguy is offline
post #11 of 11 (permalink) Old 12-14-2004, 07:18 PM
BusaBabe's Avatar
I have had that happen. The first time I thought I recked the transmission!
BusaBabe is offline
Human Verification
