Hard to start SV650 - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 12 (permalink) Old 11-04-2005, 08:23 AM Thread Starter
Hard to start SV650
My SV has had a hard time starting, lately. The battery seems fine, but I have to fully choke it for about a minute or it won't stay running on it's own. After that, it's fine.
I bought some carb cleaner, but I haven't had time to tear the bike down and get to the carbs to spray them out yet.
Is there anything else I should be looking for?
post #2 of 12 (permalink) Old 11-04-2005, 08:28 AM
That seems to happen when the temperature gets cooler. Are you sure you need to go through all that.
post #3 of 12 (permalink) Old 11-04-2005, 08:44 AM
DAN DUBEAU's Avatar
It's a carbed suzuki. My Katana is the same way. My atv is the same way, my buddies....etc. just par for the course.
A twist of the wrist and a twist in the road
DAN DUBEAU is offline
post #4 of 12 (permalink) Old 11-04-2005, 12:54 PM
2FURYUS's Avatar
Full choke for a minute doesn't sound like a problem, especially if it runs fine after that.
YA THINK???
2FURYUS is offline
post #5 of 12 (permalink) Old 11-04-2005, 01:55 PM
Yeah I would have to agree... run it full choke for 2 mins... if it's cold that is parf the coarse.
Didn't N4S have this problem and he got them cleaned and sync'ed???
So try full choke for 2 mins and see if it runs good after that.
post #6 of 12 (permalink) Old 11-08-2005, 09:21 PM
As long as it starts with the choke and it runs fine at normal operating temperature, you probably don't have a problem.
post #7 of 12 (permalink) Old 11-08-2005, 10:00 PM
Thank god mine has fuel injection.
post #8 of 12 (permalink) Old 11-08-2005, 10:04 PM
did you try checking the rotogirder?... f3 is having the same thing....its takin longer to warm up now then before, i dont have to hold it on a min but damn near close
post #9 of 12 (permalink) Old 11-08-2005, 10:16 PM
1 more from 100
post #10 of 12 (permalink) Old 11-08-2005, 10:31 PM
Shan you posted in another thread that you sprayed it with carb cleaner... how did it effect this?
post #11 of 12 (permalink) Old 11-09-2005, 12:04 AM
April 2006 BOTM Winner!
R1up0n1's Avatar
Send a message via AIM to R1up0n1
Shan...change the spark plugs to NGK....or get new ones.
-My 2004 YZF-R1 - GYTR Exhaust, HID's, BMC Filter, PUIG DB, PCIII and more...
-2000 SV650 = Sold
-2003 R1 = Demolished, Sold
-2004 R1 = Lovin it!
http://www.myspace.com/r1upon1
post #12 of 12 (permalink) Old 11-09-2005, 01:19 AM
No Worries's Avatar
My CBR uses Keihin carbs. Cleaned them many times, but not the choke plungers. The carbs have to be separated from each other and I don't want to do that. Here's how I clean them.
I turn my gas tank petcock to off when I come down the alley to my garage. The engine dies after a few minutes, and I let it cool down. The fuel line and float chambers are now dry. I disconnect the fuel line from the tank and pour carb cleaner into the line using a funnel until the float chambers and line are full. Then I connect the line back to the tank.
With the engine cool, I put the choke on full and start it. The carb cleaner from the float chamber and fuel line is running through the choke plungers and passageways. After a few minutes, fuel is running through the clean choke system. Not as good as taking the carbs apart from each other, but a lot less stripped screw heads.
Human Verification
