Shifting into first. - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 17 (permalink) Old 05-07-2007, 12:42 PM Thread Starter
I bought a F4i new last year and when I am in nuetral with the bike running and shift it into first it is a solid click. It almost seems to solid. It does not grind and never has. I was just wondering if anyone else experiences this. It will also do this when shifting up to second when sitting. This only happens when sitting never when moving. All adjustments are per the honda service manual. Thanks.
bman1179 is offline
post #2 of 17 (permalink) Old 05-07-2007, 12:50 PM
My Ninja does it. Never had any problems from it.
metalmaster1310 is offline
post #3 of 17 (permalink) Old 05-07-2007, 01:06 PM
Where are your RPM's at when you shift? That does have something to do with the sound of the shift into first...
post #4 of 17 (permalink) Old 05-07-2007, 01:24 PM Thread Starter
My rpms would be at idle (1300rpm) with the clutch pulled in, sitting still. It has done it since new and it seems pretty normal. Also it seems like it this typically when the bike is cold. When I ride for awhile and the motors hot if I stop at a light and flick it into nuetral and when the light turns green I put it into first this does not happen. Maybe when the motors hot the clearances loosen up and the oil is fully circulated and coating everything, i.e(shift forks, drum, transmission gears.)???
bman1179 is offline
post #5 of 17 (permalink) Old 05-07-2007, 02:00 PM
My R1 does it too. Sitting at a stop light if I shift to neutral to relax my hand- then shift back into first when the light turns green- I get a very pronounced shift. I thought maybe my clutch wasn't adjusted correctly but the dealer claims they all do it. Mine does it more though when the engine is hot. My 99' ZX750 did it too, so I am inclined to believe the dealership...
TOMMYTOM is offline
post #6 of 17 (permalink) Old 05-07-2007, 02:07 PM
Never been on a bike that DIDN'T have a pronounced shift out of neutral.
post #7 of 17 (permalink) Old 05-07-2007, 02:19 PM
jtemple's Avatar
Both of my bikes do it.
2006 Kawasaki ZX-10R
jtemple is offline
post #8 of 17 (permalink) Old 05-07-2007, 02:25 PM
Its all very normal. My Z does it and all of my dirt bikes did it.
post #9 of 17 (permalink) Old 05-07-2007, 02:39 PM
freeriders98's Avatar
My bike does it as well. Although my bike takes a while to get warm, and so once it is good and warm it idle's a bit higher and I notice it more then, you could back off your idle a little bit. I try to idle my bike at about 1000rpm.
freeriders98 is offline
post #10 of 17 (permalink) Old 05-07-2007, 03:06 PM
yep mine does it as well..
your all good.
post #11 of 17 (permalink) Old 05-07-2007, 07:55 PM
your bike is supposed to make that solid click noise when you put it in first, its kinda saying "careful you're in gear now" ya know? my dirt bike does it, my EX500 did it, both CBR's I was on did it, its something of a safety feature to warn you you just put it in gear.
post #12 of 17 (permalink) Old 05-08-2007, 06:00 AM
No worries, friend.
post #13 of 17 (permalink) Old 05-08-2007, 10:48 AM
I agree with all, my F4i does it too as well as my R6. It's louder and more noticeable when the bike is cold but isn't that loud when the bike is warmed up.
rockinthef4i is offline
post #14 of 17 (permalink) Old 05-08-2007, 12:09 PM
dubbs's Avatar
Yep my zzr does the same when I shift to first.. it sounds like a clunk rather then a click like the rest of the gears.. Seemed normal to me..
dubbs is offline
post #15 of 17 (permalink) Old 05-10-2007, 09:17 PM
First... make sure your clutch is adjusted correctly.
Second and more likely to reduce the THUD... try lowering your idle.. it should help. That is also why it does it more when the bike is warm. Cause with the oil hot along with the carb (if you have it) the motors idle will be higher and therefor cause more clunk into first.
post #16 of 17 (permalink) Old 05-19-2007, 12:00 AM
Not that I have a sports bike (yet), but my dirt bikes all do it.
MN-750R is offline
post #17 of 17 (permalink) Old 05-19-2007, 05:26 AM
If you ever ride in a group youll hear every bike do it so yeah it normal. Go to any bike show and youll hear every high dollar bike do it along with the drag bikes.
k_bick is offline
