Reflector Help - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 15 (permalink) Old 06-06-2007, 09:29 AM Thread Starter
Reflector Help
I recently bought this gem of a bike and want to know how to remove the swingarm reflectors that the guy put on the bike.
RC51Joe is offline
post #2 of 15 (permalink) Old 06-06-2007, 10:05 AM
man, why the eff did he do that... are they put on with adhesive? like double sided tape?
post #3 of 15 (permalink) Old 06-06-2007, 10:07 AM
Man, why the eff did he do that?.... anyways, are they put on with an adhesive? like double sided tape?
Sick bike by the way, and ... you will see that
oops i double posted....
post #4 of 15 (permalink) Old 06-06-2007, 10:10 AM
a heat gun and goo gone if it is adhesive
post #5 of 15 (permalink) Old 06-06-2007, 10:10 AM Thread Starter
They are stuck on with adhesive
RC51Joe is offline
post #6 of 15 (permalink) Old 06-06-2007, 10:11 AM
Well in that case, with trip
I have have trouble, after you get them off you may need to use some rubbing alcohol or other solvent to remove the remainder of the residue.
post #7 of 15 (permalink) Old 06-06-2007, 10:12 AM Thread Starter
The adhesive won't hurt the swingarm? It won't mess with whatever coating is on it?
RC51Joe is offline
post #8 of 15 (permalink) Old 06-06-2007, 10:13 AM
no, it will just be like removing a sticker, heat it up with a heat gun to get it to peel off easier and squirt some goo gone on there to clean it all off. Works like a charm.
post #9 of 15 (permalink) Old 06-06-2007, 10:13 AM
The adhesive is already on there... you just want to get it off without doing damage... your swingarm is tough. I imagine it's probably powder coated or otherwise treated... be a little careful with the heat gun, but otherwise you should be fine. And like I said some solvent afterwards should clean it up, and that won't hurt the swingarm either. If this were on your paint we might need to be a little more careful, but you should be all set.
post #10 of 15 (permalink) Old 06-06-2007, 10:14 AM Thread Starter
Thanks guys, I will try this as soon as I get home tonight!!!! TWF Rocks!!!!!
RC51Joe is offline
post #11 of 15 (permalink) Old 06-06-2007, 10:52 AM
post #12 of 15 (permalink) Old 06-06-2007, 02:42 PM
WD40 is also suppose to work to remove the left adhesive.
post #13 of 15 (permalink) Old 06-06-2007, 09:01 PM
dscort's Avatar
works good on faded plastic on cars too,
dscort is offline
post #14 of 15 (permalink) Old 06-07-2007, 10:15 AM
For that you can use mother's back to black... does wonders for faded plastic trimming!
post #15 of 15 (permalink) Old 06-10-2007, 11:06 AM
mondos06cbr1000 is offline
