Engine case question - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 12 (permalink) Old 05-26-2006, 07:12 PM Thread Starter
I had a thought earlier today, on my ZX what is the engine case made out of? I had a thought of welding it back together and doing the rebuild it needs. if I can figure out what the case is made from I can determine the proper welding method to fix it, and make it ridable.
its either that or replacing a motor, and I dont want to spend that kind of money on a new motor/tranny combo.
post #2 of 12 (permalink) Old 05-26-2006, 08:14 PM
good question.......... im thinking..............
post #3 of 12 (permalink) Old 05-27-2006, 12:48 PM
Well they'll either be alum or magnesium....
post #4 of 12 (permalink) Old 05-27-2006, 02:15 PM Thread Starter
I'm thinking magnesium is it. theres one easy way to find out.... I'm gonna get some of the loose chunks and have someone with a metallurgial background tell me.
post #5 of 12 (permalink) Old 05-27-2006, 03:15 PM
whatever it is, its surely cast. I dont know if you can cleanly weld cast metals due to its porosity. I may b e wrong though.
post #6 of 12 (permalink) Old 05-28-2006, 11:59 AM
ok i did some looking; cast aluminum can be welded but needs to be welded with superalloy 5 only.
post #7 of 12 (permalink) Old 05-28-2006, 01:54 PM
If it is magnesium I wouldnt recommend welding it cuz it will catch on fire and burn out of control untill it is all gone. And water makes it burn faster. So good luck!
post #8 of 12 (permalink) Old 05-28-2006, 05:59 PM Thread Starter
Oh for the record, there IS a way to weld magnesium, but it requires special equipment and knowledge to do so.
post #9 of 12 (permalink) Old 05-28-2006, 06:14 PM
It's Magnesuim. I took mine off to get chromed. I had to pay extra because it's takes a little more work to chrome it.
1BadKaw is offline
post #10 of 12 (permalink) Old 05-28-2006, 07:40 PM Thread Starter
Thank you. saved me some time. looks like I'm getting a welding shop to do heliarc welding.
post #11 of 12 (permalink) Old 05-28-2006, 08:03 PM
let us know how it goes. Mag is supposed to be more difficult than just firing up a TIG. id like to see the results.
post #12 of 12 (permalink) Old 05-29-2006, 01:57 AM
I had a boat motor fixed like this once. It held up for three more seasons and blew a hole in the other side.
