Yes, helmets work! - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 44 (permalink) Old 05-31-2007, 11:06 PM Thread Starter
Yes, helmets work!
I believe I may have posted this before, but I couldn't find the original thread. Anyway, here it is again.
But this guy disagrees:
post #2 of 44 (permalink) Old 05-31-2007, 11:25 PM
dubbs's Avatar
Tatoo Jesse is a retard in more ways then I care to describe..
dubbs is offline
post #3 of 44 (permalink) Old 05-31-2007, 11:31 PM
Dale Earnhardt plowed his face through a steering wheel, it was a little more than a helmet snapping his neck.
I do agree with that guy about banning cellphones/food/drink while driving, msf for everyone, and 1 year in jail for DUIs as well.
post #4 of 44 (permalink) Old 06-01-2007, 08:14 AM
Is it true that the requirement on helmets is that they be able to withstand direct impact at just 14.5 miles/hour?
logan1 is offline
post #5 of 44 (permalink) Old 06-01-2007, 08:41 AM Thread Starter
I agree with the above as well.
Well, I don't see anything about a specific MPH, but I also didn't try to read the entire wording. http://www.webbikeworld.com/motorcyc...T-standard.htm
post #6 of 44 (permalink) Old 06-01-2007, 08:51 AM
That's a little simplified: the actual TEST(S) involve multiple strikes on helmets for both penetration (a pointed striker) flat solid surface tests (dropped on a flat anvil with a headform inside) and curved solid surface tests (dropped on a curved anvil with a headform inside)...and multiple strike tests, where the helmet is re-subjected to strikes in the same area( to simulate your head bouncing along the road).
The MPH figures are deceiving: Fatal head injuries occur in the 7mph range (yep, truth). That's how fast your head would contact a solid surface at a drop from 4ft, unimpeded to a curved or pointed surface (like a rock). The fact is that you have to take into account how most bike accidents happen, and then factor in how most motorcycle head injuries occur to determine reasonable standards for helemt construction.
The old Snell standards were developed for racecar drivers, who were subjected to different types of headstrikes than bikers.....bikers were dying with incorrectly constructed Snell helmets. New Dot, Snell, and Ansi specs take into account the difference in motorcycle on auto accidents.
The mean speed motorcycle accidents occur at is 21 mph. Unless you suffer direct contact with your head (horizontal speed, NOT verticle speed) to a solid (like a brick wall....contact with an auto will be different because sheetmetal and plastic deform, absorbing energy) object, the helmet will most likely do it's job.
The problem with guys like "Tattoo Jesse" is that they never paid attention in physics class; (they were out smokin' a joint in the boys bathroom during the lecture on thermodynamics) therefore when they hear "14 mph" they only focus on that one small piece of info, not knowing that your helmet can absorb TWICE the lethal dose of kenetic energy (E=Mass*Velocity) in a single strike....much more if you calculate multiple strikes.
oldetymebiker is offline
post #7 of 44 (permalink) Old 06-01-2007, 09:27 AM
Nice job with the rant, buttt that has NOTHING to do with thermodynamics, also E, there is no such thing as E alone, does not equal mass*velocity, that would be force my friend, measured in Newtons. KE (kenetic energy is calculatated as 1/2mgh, also equal to U [aka PE for potential energy]) Perhaps you two should take a few pysics classes
jmat2407 is offline
post #8 of 44 (permalink) Old 06-01-2007, 09:54 AM
physics don't apply to motorycycle accidents. the natural law of karma prevails. i crashed at the track at over 120 mph. my helmet was unscratched. is this physically possible? of course it is.
using OTB's reasoning, my head before i fell was about 2 feet from the ground. i was kneedragging. rear end hit the edge of the track and i slid. karma dictated that i was a fine young gentleman and allowed me to slide harmlessly and not go airborne as other riders have.
not true, i slid then tumbled. still, my helmet didn't get damaged. but my body was battered. it hurt.
physics usually applies to controlled conditions. real world is not a controlled environment.
post #9 of 44 (permalink) Old 06-01-2007, 10:08 AM
I agree with 95% of what Tattoo Jesse was saying... Except for the crap about helmets...
post #10 of 44 (permalink) Old 06-01-2007, 10:14 AM
It's simple. You have two choices:
a. Ride with helmets and gears.
b. Ride without.
It is your choice and your choice only. It doesn't hurt me if you ride without gears or helmet. It hurts you if you crash, but it sure as hell doesn't hurt me.
So why don't we all leave each other be? Ride your own ride. Wear your own gears. Let others do what they wish as far as personal protection goes.
fnfalman is offline
post #11 of 44 (permalink) Old 06-01-2007, 10:18 AM
Nice try, but pretty much everything you said to try to prove OTB wrong is wrong itself. Mass*velocity is NOT force. It is momentum. Ever hear of Newton's Law? Force = mass * acceleration, measured in Newtons.
Also, there is such a thing as E, it is total energy, the sum of all energies.
Regardless, Kinetic energy and potential energy are NOT the same thing. PE (or U as you called it) due to gravity ONLY is 1/2mgh. Kinetic energy due to translation is 1/2mv^2. These two things are only equal in very specific (and unrealistic) cases.
Before you try to trounce someone else's post after taking a half a year of a HS physics class and then misquoting half of the information, you should do your homework.
post #12 of 44 (permalink) Old 06-01-2007, 10:37 AM
Pardon me. I simplified. Didn't want to get into ALL the math, as I frequently get "Cliff's Notes" comments when I get too technical or wordy. Again, excuse me. Guilty as charged.
And my comment about being high during the thermodynamic lecture was simply meant to be a general, albiet humorous one.
And as far as a Rant? I don't believe that could be construed as a rant. The comment was about putting the 14.5 mph standard in CONTEXT....that's all.
Sheesh......ya'll get up on the wrong side of the bed today? Lighten up.
Next time I'll post the charts, graphs and footnotes for you.
post #13 of 44 (permalink) Old 06-01-2007, 10:41 AM
We'd appreciate that...
post #14 of 44 (permalink) Old 06-01-2007, 10:43 AM
I wasn't flaming you, just the kid trying to correct you with his own INCORRECT information. Ignorance is bliss, I suppose.
Your posts are always great OTB
post #15 of 44 (permalink) Old 06-01-2007, 10:48 AM
HAHAHAHHAAHHA, you can't be serious. Physics can explain every situation you have in your wrecks......... Karma is a load of s**t.
post #16 of 44 (permalink) Old 06-01-2007, 10:50 AM
My psychic advisor says you are wrong...
post #17 of 44 (permalink) Old 06-01-2007, 10:50 AM
thanx for the explanation.
logan1 is offline
post #18 of 44 (permalink) Old 06-01-2007, 10:52 AM
i agree his idea on restricting cell phone while driving alone will save a lotta life if implemented.
logan1 is offline
post #19 of 44 (permalink) Old 06-01-2007, 10:53 AM
Don't even get me started on this one...
post #20 of 44 (permalink) Old 06-01-2007, 10:55 AM
Ask your psychic advisor how many visits you are going to attend so she can go ahead and rip you off in one big payment.
