Probably gonna get flamed - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 19 (permalink) Old 06-11-2006, 05:50 PM Thread Starter
I know there is a million and one oil threads on here but I don't know if this particular one has discussed before, I couldn't find a thread but if ther is one just let me know. Anyway, I got my bike and I don't know what the last owner used for oil. Ive tried to get in touch with him but its a complicated situation, Anyway, I was wondering if he didn't use full synthetic is it safe to go straight to a full syn oil or should I first do a syn blend and then go to a full syn. Or if he did and I used nonsynthetic, but changed the oil after say 1K miles would that cause any damage. Ive heard that once a full syn has been used you are suppose to ween it back to regular oil slowly. I plan to use a full synthetic but I want to do some more research to find out which is the best to use. Everyone seems to have their own opinion so I need to form my own opinoin.
frostz28 is offline
post #2 of 19 (permalink) Old 06-11-2006, 07:35 PM
Switch to amsoil and don't look back. Just remember that just because you use sync... doesn't mean you don't have to change it less often!!!!
post #3 of 19 (permalink) Old 06-11-2006, 07:52 PM Thread Starter
Yeah I actually have to resist the urge to change my oil. Everytime It rains I want to do something with my bike so I think I should go ahead and change the oil. Even though I just changed it. So changing it TOO often is more of a problem. But basically if it wasn't a full syn before and I switch to a full syn it won't be bad for the bike, correct?
frostz28 is offline
post #4 of 19 (permalink) Old 06-11-2006, 08:18 PM
Use what ever you want. Just get the right weight.
post #5 of 19 (permalink) Old 06-11-2006, 09:01 PM
ne1469 is offline
post #6 of 19 (permalink) Old 06-11-2006, 09:38 PM
^YEP!^
post #7 of 19 (permalink) Old 06-12-2006, 01:05 AM Thread Starter
15-40? Thats what most people I talk to use.
frostz28 is offline
post #8 of 19 (permalink) Old 06-12-2006, 06:48 AM
It should say in your manual what weight to use. My Gixxer uses 10w40.
post #9 of 19 (permalink) Old 06-12-2006, 08:57 AM Thread Starter
I know I don't have a manual and I can't seem to find one. Ill have to try to look it up on the net.
frostz28 is offline
post #10 of 19 (permalink) Old 06-12-2006, 08:58 AM
My guess is 10w40.
post #11 of 19 (permalink) Old 06-14-2006, 07:40 PM
Whats up guys. Frost....good question because I was about to ask the same question. I don't know what the previous owner used in my bike and I am creeping up on 1K miles on my new bike. I most defiantly want to use full synthetic, but I didn't know if I should ease into it.
After reading this thread...I am going to find the best 10W-40 Full Syntetic I can find and get riding.
Thanks guys,
DempsRS is offline
post #12 of 19 (permalink) Old 06-14-2006, 11:15 PM Thread Starter
Thanks guys,
Just make sure its "heavy Duty" oil, also often referred to as Disel oil, (you should be familiar with anything Disel run) or one that is formulated for bikes. I think thats right anyway, I know I need it for my bike but I guess it may be diffrent for older bikes. Any advice on that? there is another thread on here where someone posted and article written by a guy who listed a bunch of oils that were good for bikes. I don't remember the name of it but if you do a search for "motorcycle oil" it should come up in there somewhere. Hey what type of oil did you guys use on your buddies ninja? I gotta get down there and see that beast sometime.
frostz28 is offline
post #13 of 19 (permalink) Old 06-14-2006, 11:19 PM
Don't use any diesel oils in your bike. Most all oils today are compatible for bikes. Search for some of the other oil threads here for some great reads and info.
post #14 of 19 (permalink) Old 06-14-2006, 11:56 PM Thread Starter
HUH. thats good to know. don't you need to run "heavy duty" oil? Ive heard that a lot. perhaps the people that I talk to say Diesel oil when they are referring to Heavy duty oil.
frostz28 is offline
post #15 of 19 (permalink) Old 06-15-2006, 01:15 AM
Diesel oil has detergents in it that you don't want in a gas motor. Especially a bike with a wet clutch like most. Most all automotive (car) oils are fine if you don't want to spend the bucks for a bike specific oil.
I'm looking for the best oil thread now.
post #16 of 19 (permalink) Old 06-15-2006, 01:18 AM
Here is one of the better thread on oil. Click
post #17 of 19 (permalink) Old 06-15-2006, 02:35 AM Thread Starter
Thats the one I was thinking of. And now for my next stupid question. What do the numbers in the oil stand for? I see Rotella 5-40 is mentioned in there. Thats what I was considering using in my bike. The author of that says that Rotella 15-40 is one of his fav. but I really want to use a synthetic oil in my bike. Is the 5-40 to thin or thick for my bike. I live in Northern Il. where the temps summers are hot and the winters are cold but I don't ride my bike unless its warm or hot out. Again I don't know what the owners manual says because I don't have one, but all the other mauals I read recommend either 10-30 or 15-40. Most of the newer bikes seem to be 15-40. Is the 5-40 an acceptable alternative?
frostz28 is offline
post #18 of 19 (permalink) Old 06-15-2006, 04:49 AM
Dont get 'energy conserving' oil either. The additives are bad for your bike I believe.
post #19 of 19 (permalink) Old 06-15-2006, 12:10 PM
Your on the right track Frost. The first number is basically the thickness of the oil. Lower being thinner. I use thinner in the cold and visa versa. Actually, I use the recommended weight year round.
