NOT servicing the cam chain tensioners - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 12 (permalink) Old 06-21-2006, 02:41 PM Thread Starter
I've got 17000 miles on my '99 SV650S and I've never had a valve adjustment or cam chain tensioner adjustment. The bike runs fine, as far as I can tell. I've replaced the brakes, redone the forks, replaced the sprockets and chain, replaced the plugs, jetted the carb, replaced tires and the oil is changed regularly so it's not like I completely abuse it.
Am I on borrowed time or should I stop riding and have this done immediately?
post #2 of 12 (permalink) Old 06-21-2006, 03:27 PM
I had 19k+ on my 00 SV650 and never had the cam chain tensioner adjusted and there wasn't any problems. Also I took the bike in to have the valves looked at and adjusted, however when the tech took it apart he said there was SO LITTLE wear he didn't even have a shim that could possibably fit it. So therefore the valves were fine.
All in all the top end of the engine was perfectly fine with all those hard miles on it. Turns out my problem was too many wheelies, starving the front cylinder and throwing a rod bearing and scoring the crankshaft.
post #3 of 12 (permalink) Old 06-21-2006, 04:50 PM
my motor is getting a little noisy. (mechanically) The manual cam chain tensioner is an up coming mod for me. I hope im not on borrowed time either.
post #4 of 12 (permalink) Old 06-21-2006, 08:27 PM Thread Starter
Well that's somewhat reassuring. I don't ride too hard () but I should probably have it checked.
post #5 of 12 (permalink) Old 06-21-2006, 09:21 PM
It wouldn't be a bad idea, however be prepared to hear there is nothing wrong with them.
post #6 of 12 (permalink) Old 06-21-2006, 11:02 PM
Its called PREVENATIVE maintance!
I wouldn't say STOP riding... just sked the time to either have it done or do it on the w/e in the coming month or so.
post #7 of 12 (permalink) Old 06-22-2006, 02:15 AM
If you don't hear it. I wouldn't worry to much but it is time for a checkup.
post #8 of 12 (permalink) Old 06-22-2006, 05:42 AM
Anyone know about what a shop charges to adjust it?
post #9 of 12 (permalink) Old 06-22-2006, 11:59 AM
Shouldn't be more than 1 hour shop rate for most bikes.
post #10 of 12 (permalink) Old 06-22-2006, 10:12 PM
It helps if your bike is naked like most the SVs....
post #11 of 12 (permalink) Old 06-22-2006, 10:56 PM
I think it was almost $200-$300.
post #12 of 12 (permalink) Old 06-23-2006, 04:26 AM
Well mine isn't but...it takes me about 5 minutes to get the fairings off.
