Change oil filter each time? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 14 (permalink) Old 10-05-2004, 05:09 PM Thread Starter
Do you change the oil filter on your bike each time you change the oil?
I've got one on order, but I have the oil now. I'd like to just do it, but I'm wondering if I should wait for the filter.
post #2 of 14 (permalink) Old 10-05-2004, 05:22 PM
according to the oil gurus, if I remember right, using amsoil wouldnt require changing the filter every time..but Im so used to doing it, i dont think I could change the oil w/ out changing the filter.
geez shan, ur really stirring up the oil gods today huh
Need4Speed is offline
post #3 of 14 (permalink) Old 10-05-2004, 05:38 PM
I have mine changed everytime I get the oil changed.
GSXR1000DJ is offline
post #4 of 14 (permalink) Old 10-05-2004, 06:47 PM Thread Starter
Where are the oil gods anyway?
post #5 of 14 (permalink) Old 10-05-2004, 06:49 PM
I say while ya down there(get mind outta gutter) might as well getter done. Definetly won't hurt.
jdog is offline
post #6 of 14 (permalink) Old 10-05-2004, 08:17 PM
do you wash your plate every time you eat?? Why would you want to run clean oil through a dirty contaminated filter?
post #7 of 14 (permalink) Old 10-05-2004, 08:23 PM Thread Starter
That's been my philosophy, particularly since they're so cheap. I'm just curious about the argument for not changing it.
post #8 of 14 (permalink) Old 10-05-2004, 08:49 PM
What kinda filter you planning on using boss? u going with the K&N filter, boss ?
post #9 of 14 (permalink) Old 10-05-2004, 08:59 PM
If he is a smart boss as you and I is. And I think he is. He will go with the K&N.
post #10 of 14 (permalink) Old 10-05-2004, 10:52 PM
I think the Amsoil guys said they change the filter and keep the oil, which would make more sense than the other way around. However, I change the filter every time I change the oil.
post #11 of 14 (permalink) Old 10-05-2004, 10:57 PM
And Larryg has spoken. Hear his words and live by them.
post #12 of 14 (permalink) Old 10-05-2004, 10:57 PM
WOW, Shan you got your hat on backwards!!
You ALWAYS CHANGE your filter. For God's sake ALWAYS! That is super important. As Larry said, the Amsoil guys will tell you to change the filter and leave the oil. You have to change the filter to get rid of all the dirt, containiments, and pieces of your engine out of the oil. Not to mention on a MC the pieces and shavings of your clutch! Especially you Shan with your TLS!
Just wait on the filter and do it right the first time!
Sorry for my late replies, busy at work, and had a WOS meeting tonight!
post #13 of 14 (permalink) Old 10-06-2004, 02:15 PM
Change oil and filter. Dirty oil has dirt and acids that are in suspension, too fine to be filtered by the filter. Anyway, the filter can't filter out gas and acid, plus the oil loses stability from heat aging.
I have the 2003 results from Motorcycle Consumer News, where they tested 30 oils for heat aging, anti-wear additives, acid neutralizers, and viscosity. I also have the 1994 MCN tests of synthetic vs petroleum vs car vs bike oils. I'll put the results in a separate thread (insert flaming smilie here).
post #14 of 14 (permalink) Old 10-06-2004, 02:54 PM
I have the Scotts "never ever need another" filter. It is sweet and well worth the money on race bike because you change the oil and filter very often.
