Hearing a funny noise. - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 17 (permalink) Old 06-25-2006, 01:42 PM Thread Starter
Hey guys and gals. I just changed my oil in my bike a few days ago. I rode it to work the next day and when I got there I was taking off my gear while the bike was idling and I heard a really weird noise in the head. I took my helmet off and ear down by the engine. It was a ticking noise. Something in the valve-train is ticking and I have no idea what.
This was my first oil change on my new bike. I used 20W-50 motorcycle oil and put in 4 quarts just like the manual calls for. I don't know what the hell is going on.
Has anyone experienced this before? I know this is sort of a dead end question but if anyone can relate I would apprciate some insight.
DempsRS is offline
post #2 of 17 (permalink) Old 06-25-2006, 01:57 PM
Have you checked the level on the dipstick or window? That's my only suggestion for now.
post #3 of 17 (permalink) Old 06-25-2006, 03:26 PM Thread Starter
Yeah I checked the dipstick....it seems to be right where it should be.
I wish I had a sight window though. They seem easier to use.
I might try adding some more oil anyway to see if the tick stops. That is all I can think of too.
Thanks though
DempsRS is offline
post #4 of 17 (permalink) Old 06-25-2006, 03:33 PM
the sound may have been there before you changed your oil. Youre on an F3? How many miles?
post #5 of 17 (permalink) Old 06-25-2006, 04:48 PM Thread Starter
22,000 miles. I am pretty sure the tick was not there before I changed the oil. It was rather loud after I changed the oil...
Are you saying the thicker oil may have made the tick louder???
DempsRS is offline
post #6 of 17 (permalink) Old 06-25-2006, 05:28 PM
I Rode it before the oil change and I don't remember hearing the tick at all.
frostz28 is offline
post #7 of 17 (permalink) Old 06-25-2006, 10:36 PM
22k miles, check and adjust your valves.
also, did you remember to put the air cleaner back in?
post #8 of 17 (permalink) Old 06-25-2006, 11:03 PM
post #9 of 17 (permalink) Old 06-25-2006, 11:21 PM
Thanks though
To check the oil on my 1990 CBR, the bike has to be level (on the centerstand) and the oil dipstick's top thread just touches the top thread of the inlet. Many people make the mistake of screwing in the dipstick to read the level. If you do that, you'll be 1/2 quart or more low.
post #10 of 17 (permalink) Old 06-26-2006, 03:26 PM
20W-50 on a F3?? Really?
Are you sure its just not the valve train workin?
Did you switch oil types... dino vs syn oil?
post #11 of 17 (permalink) Old 06-26-2006, 05:39 PM
thats where i was going with it-
post #12 of 17 (permalink) Old 06-27-2006, 01:25 PM Thread Starter
this was my first oil change on the bike. I have had it for about 4 weeks. It is the valve train making the noise, but it is so loud I do not think it is from just workin.
How do I adjust my valve like you guys are suggesting???????
DempsRS is offline
post #13 of 17 (permalink) Old 06-27-2006, 01:43 PM
It's tough. Shims are involved as well as ripping your motor apart.
post #14 of 17 (permalink) Old 06-27-2006, 03:46 PM
I hear ya man! Take it to a bike shop if you are not sure what you are doing. Otherwise it could end up costing you a lot more in the end
Gixxer911 is offline
post #15 of 17 (permalink) Old 06-27-2006, 09:20 PM
common newbie mistake is overtightening the valve cover bolts. they strip very easily. Valve inspections are easy, just remove the tank/airbox/carbs or EFI then the valve cover (rubber gasket should be reuseable). Check with a shop manual for locating TDC and squeeze that gauge betw the cams and shims. I'm not sure if F3 has manual or automatic cam chain tensioner.
get a shop manual before working on your bike.
post #16 of 17 (permalink) Old 06-28-2006, 03:19 AM
I always think these are going to be the CCT but hate to jump to that conclusion at first...
post #17 of 17 (permalink) Old 06-28-2006, 05:37 AM
Not good. w/ the fix.
