No Fling Chain Lube? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 12 (permalink) Old 06-30-2006, 07:08 AM Thread Starter
Anyone use this stuff? I understand it works great. Dries clear and no flinging. Does a good job of initial cleaning too from what I've read.
I'm probly gonna buy a can today...my Suzuki Chain Lube gets all over my wheels.
post #2 of 12 (permalink) Old 06-30-2006, 07:35 AM
jtemple's Avatar
I use PJ1. Normally, I use the Blue Label, which isn't supposed to fling off (and it doesn't). The shop was out of Blue, so I had to buy Black. I think it's going to be more "flingy" (is that a word?) than the Blue. We'll see!
2006 Kawasaki ZX-10R
jtemple is offline
post #3 of 12 (permalink) Old 06-30-2006, 08:50 AM
if you have 0-ring chains, you really don't have to lube it. the lube is in the 0-ring. All you need to do is keep it clean. I use wd40 to clean it then wipe it off. Chain lube is a real mess.
post #4 of 12 (permalink) Old 06-30-2006, 09:26 AM Thread Starter
Yeah it is.
post #5 of 12 (permalink) Old 06-30-2006, 01:51 PM
I use PJ1 black, applied to the inside of the chain loop after riding. The next day, the lube is like wheel bearing grease and won't fling.
post #6 of 12 (permalink) Old 06-30-2006, 05:57 PM
That dupont teflon stuff is GOOD $#!t- I use it for everything possible! Still, most lube wont fling if you let it sit long enough. But get the teflon anyway.
post #7 of 12 (permalink) Old 06-30-2006, 06:49 PM
Marko...if you get your new chain setup you wno't need to do that... just clean the chain with kero and you're done!
post #8 of 12 (permalink) Old 06-30-2006, 08:31 PM Thread Starter
I was to the understanding that you need to shoot the chain with some shiz every so often.
post #9 of 12 (permalink) Old 06-30-2006, 09:26 PM
jtemple's Avatar
I lube mine every 600 miles per the owner's manual.
jtemple is offline
post #10 of 12 (permalink) Old 06-30-2006, 09:28 PM Thread Starter
Yeah...mine says something to that effect.
post #11 of 12 (permalink) Old 07-01-2006, 12:55 AM
lube it to keep the o-rings from dry rotting. not necessarily lube the chain. there is lubricant trapped inside the 0-ring. you just need to keep it clean.
post #12 of 12 (permalink) Old 07-01-2006, 02:06 PM
Like BM says you don't need to "lube" the o or x-ring chains!
