Neutral no workie HELP! - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 36 (permalink) Old 07-08-2006, 06:53 AM Thread Starter
ibuyvettes's Avatar
Just bought my first bike. It is a 93 GSX R 600 with an 1100 motor out of a 95. No matter how hard I try I can't get it in neutral. Anyone have any idea? Shifts just fine otherwise. I work on my own cars but this bike is a new animal and I know nothing about them yet.
ibuyvettes is offline
post #2 of 36 (permalink) Old 07-08-2006, 07:47 AM
Hmm. It just shifts directly into second? Does it feel like it wants to go, but slips out into second or first (when trying to get in N from second)?
Can a worn clutch cause this?
post #3 of 36 (permalink) Old 07-08-2006, 10:04 AM Thread Starter
ibuyvettes's Avatar
No it won't go out of first
post #4 of 36 (permalink) Old 07-08-2006, 11:10 AM
Adjust the freeplay at the clutch first, or bleed the fluid if it's a hydraulic clutch. Then go from there.
post #5 of 36 (permalink) Old 07-08-2006, 12:09 PM
it never leaves 1st?
post #6 of 36 (permalink) Old 07-08-2006, 12:51 PM
My FZR did that, it was a rod that broke off inside the clutch boss, PITA to fix, i noticed it felt like it was skippin teethe then BANG! stuck in first, mite be the same prob
stomper173 is offline
post #7 of 36 (permalink) Old 07-08-2006, 12:55 PM Thread Starter
ibuyvettes's Avatar
Nope! no neutral, 2nd etc.
post #8 of 36 (permalink) Old 07-08-2006, 01:11 PM
a little off topic, but how is your clutch is activated? because the 93 gsxr600 used a cable and the 95 gsxr1100 uses hydrolic. i guess the 1100 controls were used?
post #9 of 36 (permalink) Old 07-08-2006, 01:15 PM
yea and theres a 5 spd in the 11, jus incase you didnt know, maybe sompin aint compatible
post #10 of 36 (permalink) Old 07-08-2006, 02:08 PM Thread Starter
ibuyvettes's Avatar
Yeah it's got the 5 speed box, and it was working last night.
post #11 of 36 (permalink) Old 07-08-2006, 04:34 PM
i wonder if a shift fork was bent.
but just a few more questions: does the bike completely disengage with the clutch in or does it try to walk a little?
post #12 of 36 (permalink) Old 07-08-2006, 06:03 PM Thread Starter
ibuyvettes's Avatar
It does walk.
post #13 of 36 (permalink) Old 07-08-2006, 06:28 PM
I would say bad clutch.
post #14 of 36 (permalink) Old 07-08-2006, 07:13 PM
what do yall think, warped clutch plates? Do what NoWorries says first, then pull the plates and see if theyre warped.
post #15 of 36 (permalink) Old 07-08-2006, 10:31 PM
And to check the plates... put them on a large piece of glass. Not a car window but like a door wall, or glass table.
post #16 of 36 (permalink) Old 07-09-2006, 10:53 AM Thread Starter
ibuyvettes's Avatar
I could not eveb tell you where the clutch is on this thing. I just took it to the shop, hopefully they'll at least lube up before I bend over.
post #17 of 36 (permalink) Old 07-09-2006, 11:35 AM
Sometimes that is the best bet!
post #18 of 36 (permalink) Old 07-09-2006, 12:09 PM
once you start openin cases and covers you never know what lil suprises are waiting to kill your day
post #19 of 36 (permalink) Old 07-09-2006, 07:39 PM
well atleast you know whats coming.
BTW, the clutch is on the right side. Where you add oil.
post #20 of 36 (permalink) Old 07-09-2006, 09:11 PM Thread Starter
ibuyvettes's Avatar
Good to know! I'll figure this thing out over time. You know the first thing I did was go into a Motorcycle chat room and asked what was wrong with it. The only response I got was you have a bent shifter rod Dummy! Gee thanks jerk.
BTW here is a pic of it that the previous guy sent me. I of course have taken the tacky chrome stickers off it.
