nail in tire - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 67 (permalink) Old 07-08-2006, 08:38 PM Thread Starter
nail in tire
get up wash my bike for the first time...ride it into work...get lots of compliments...then get done work hop on 95 to go to my girls house, ride up there park her up...
guess what? i notice something that appears to be a rock in the tire...so i look its a freakin nail i pressed to see how bad it was and when i pressed down i hear *sssss* and stopped pressing and it was fine...i checked the pressure and its fine but my question is...can a bike tire be plugged?
i hope cause these are brand tires less than 500 miles so i dont wana have to buy new ones
ls1ssws6 is offline
post #2 of 67 (permalink) Old 07-08-2006, 09:51 PM
it can but i wouldnt recomend it, too much presure differences and stuff, jus spend the money on a new tyre, then yul feel safer
stomper173 is offline
post #3 of 67 (permalink) Old 07-08-2006, 09:54 PM
KillerTiller's Avatar
funny i had the same thing happen to me......rode to work on Thursday, then was going for a ride early sat morning and wham! nail in rear tire. Good thing the tire is nearly bald and needs replacing anyway but I think you will hafta replace that tire cause i don't believe they recommend patching motorcycle tires....
KillerTiller is offline
post #4 of 67 (permalink) Old 07-08-2006, 09:59 PM
it really depends on where the nail is located. If it's the rear tire...I'm assuming, and center of the tread...then a sticky plug will do just fine, don't get a patch...use a sticky plug.
I've had this happen a few times and never had a problem.
If it's the front tire I wouldn't recomend it, but it can be done.
post #5 of 67 (permalink) Old 07-08-2006, 10:11 PM
but like we said, not recomended
post #6 of 67 (permalink) Old 07-08-2006, 11:45 PM
This is true and one of those debated topics. It all depends on you.
No dice if its the front tire seems to be agreement.
Rear... depends on where on the tire and how you ride.
Remember this... above all!
You only ride on 2 tires! If one has a hole in it, with a nail or a plug. That tire has been comprimised and you are only riding on 50% of good tires.
Take that for what you want!
post #7 of 67 (permalink) Old 07-09-2006, 12:38 AM
3k miles on a gooey plugged rear tire and still no air loss.
if you drop your $500 helmet, it's been comprimised. would you fix it or buy a new one? it's your decision.
i've raced plugged tires and have ridden many street plugged tires.
i've also used inner patches for car tires. those are tricky. 20% of them leaked and had to be redone. i've patched about 50+ car tires and about 6 motorcycle tires.
i've only used the gooey plugs for motorcycles because they flex more and are prone to abuse.
theoretically, the broken metal strands in the belts will eventually saw off those solid plugs. I haven't seen one happen so i feel more comfortable with a gooey plug.
the problem with inner patch is preparation work. the inside rubber needs to be buffed. for motorcycle tires, it is very touchy. an inexperience tech can easily buff off too much and not clean it well enough which will cause leakage.
another difficult task is reaming the nail hole to a larger size. this will enable the plug and tool to fit in.
worst case senario is a slow leak. some ppl believe plugged tires will explode on hard cornering. so far, i've never had a front tire get a nail. just learn to ride a wheelie all the way home.
post #8 of 67 (permalink) Old 07-09-2006, 01:20 AM
I would just worry that you could suddenly loose tire pressure causing il-riding effects.
post #9 of 67 (permalink) Old 07-09-2006, 01:37 AM Thread Starter
well i guess thats good because it is the rear tire and it is smack in the middle of the tire, not on the side...so what ill probably do is take it to a bike shop and have them use a "gooey" plug then just check the tire pressure before each ride and if its low ill just fire up the air compressor at my dads house also my tires say cold psi should be 42, when i check it was about 30 on that tire is that ok or should i get more? this was after doin some hard riding as well
ls1ssws6 is offline
post #10 of 67 (permalink) Old 07-09-2006, 01:40 AM
your shop probably won't plug that tire due to liablilty issues....best bet is to go to autozone, advance auto, or walmart or something and buy the sticky plug and do it your self.
post #11 of 67 (permalink) Old 07-09-2006, 12:25 PM Thread Starter
ahh i see...is it hard to plug a tire yourself?
ls1ssws6 is offline
post #12 of 67 (permalink) Old 07-09-2006, 12:49 PM
No its quite easy!!
post #13 of 67 (permalink) Old 07-09-2006, 01:03 PM
Originally Posted by Gas Man
No its quite easy!!
if you can stab things, you can plug a tyre
post #14 of 67 (permalink) Old 07-09-2006, 01:57 PM
here's a repost on getting screwed
use soapy water to find the leakage and to test after you plugged it.
unscrewed
I also used a drill instead of reaming it to make the hole larger
post #15 of 67 (permalink) Old 07-09-2006, 03:12 PM
Good call man, good post
post #16 of 67 (permalink) Old 07-09-2006, 07:01 PM
Coincidence, indeed.
After getting back from a trip to Tennesse and the Honda Hoot, I finally got around to washing and polishing up my bike. I bought some rim trim at the Hoot and put that on, then took off for Curves and Karate. I thought the trim look terrific, so when I got home I asked my husband to take the bike down the street so I could see what it looked like in motion, and as he went behind the bike he spotted a screw in the back tire. We don't know how long it was, and the head was a sticking out a bit, like I'd just picked it up on our street or driveway.
Long story short, my bike's getting two new tires. Guess it's good for me that I've got about 7000 miles on those tires. (The front tire was cupping anyway.)
Anyway, my vote is to be very cautious about plugging the tire.
Hotshoe is offline
post #17 of 67 (permalink) Old 07-09-2006, 08:21 PM
Tip: be liberal with the cement for the sticky plug. Too much is waaaaaaay better than not enough in this case.
post #18 of 67 (permalink) Old 07-09-2006, 11:10 PM
post #19 of 67 (permalink) Old 07-10-2006, 01:14 AM Thread Starter
unscrewed
reaming a lil help on this one?
ls1ssws6 is offline
post #20 of 67 (permalink) Old 07-10-2006, 04:24 AM
Use a drill and a drill bit.
