shift light gsxr 1000 2006? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 11 (permalink) Old 07-24-2006, 08:05 PM Thread Starter
I have a new gsxr 1000 how do i set the shift light . thank you for all your help!!!
hulsey is offline
post #2 of 11 (permalink) Old 07-24-2006, 09:37 PM
Read the manual. It's in there.
post #3 of 11 (permalink) Old 07-24-2006, 09:47 PM
post #4 of 11 (permalink) Old 07-24-2006, 11:10 PM
Yup. The manual doesn't do the best job of explaining it, but you'll get it if you stare at it long enough. Only took me about 5 minutes to figure out.
Audiomechanic is offline
post #5 of 11 (permalink) Old 07-26-2006, 11:44 PM
Audio...why don't you just give up the info?
Also
post #6 of 11 (permalink) Old 07-27-2006, 06:25 AM
Sorry Gas. I was gonna but...uh...I broke my finger on the enter key!....my mom died!....The president asked me to save the world!!!..............not buyin it huh. Ok, I was tired and lazy.
Here goes nothin:
1) Hold down SEL button and turn key on. Keep button held down for a couple seconds.
2) Push ADJ button to change the lighting mode. It goes from LIGHT > BLINK > NO LIGHT > LIGHT .....and so on. When you have the light turned on you'll see a little "Lighting bolt" symbol in your gear indicator window.
3) Press the SEL and then the ADJ button repeatedly to change the brightness of the shift light.
4) Press the SEL button and then the ADJ button repeastedly to select the RPM at which the light will come on. As you push the ADJ button, you'll see the Tacometer needle move at 500 RPM steps upward.
5) When you're happy with the selction, press the SEL button and then turn the key off.
6) Turn key back on, start bike and go try it out!
post #7 of 11 (permalink) Old 07-27-2006, 06:27 AM
post #8 of 11 (permalink) Old 07-27-2006, 10:52 AM
Rep'd ya for the description.
post #9 of 11 (permalink) Old 07-27-2006, 05:52 PM
PHAT! Can I do this: without being gay? I didn't think so.
post #10 of 11 (permalink) Old 07-27-2006, 06:08 PM
post #11 of 11 (permalink) Old 07-28-2006, 07:10 AM
Now that's a good post... rep pt comin your way!
