Fuel pump not turning off - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 7 (permalink) Old 07-26-2006, 03:33 PM Thread Starter
When I turn off my bike (01 zx7r), I hear noise coming from the fuel pump. The only way I can get it to shut off is by disconnecting the battery. Do I need a new pump or is it a wiring problem? Any help would be greatly appreciated.
wubones is offline
post #2 of 7 (permalink) Old 07-26-2006, 05:52 PM
Hmm. Tricky. I'd check your connections first. Hopefully that will take care of it.
post #3 of 7 (permalink) Old 07-26-2006, 07:05 PM
I'll assume it's a fuel pump for carbs. I too would check the wire connections going to the fuel pump and relay. I would also check the wires for frays or if it's being pinched to cause a ground. Like when a car horn won't shut off, the relay or fuel pump may have a ground ahead of the ignition switch. No fuse will blow on a ground, because the running pump prevents excess current flow.
post #4 of 7 (permalink) Old 07-27-2006, 02:39 AM
A wiring diagram would help ALOT!
post #5 of 7 (permalink) Old 07-27-2006, 02:43 AM
It may just be the relay too.
post #6 of 7 (permalink) Old 07-27-2006, 06:49 AM
post #7 of 7 (permalink) Old 07-28-2006, 01:40 PM Thread Starter
thanks alot for the help. ill pull the tank and see whats up.
wubones is offline
