520 chain converson?? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 16 (permalink) Old 08-21-2006, 11:48 AM Thread Starter
I have a 97 GSX R750 that is fully stock and in great shape. I had asked you you guys what kind of up grades I should do. well one of the suggestions that was given was to do a 520 chain converson -1 tooth front & +1 rear sprockets. At this time my rear sprocket is pretty worn and my chain near its end so I figured if I was going to replace them I would do the 520 converson. So my ? is, what does a 520 converson do?
anyexcus2ride is offline
post #2 of 16 (permalink) Old 08-21-2006, 11:52 AM Thread Starter
P.S.
Thanks for the Help
post #3 of 16 (permalink) Old 08-21-2006, 11:58 AM
You're actually going to change the Size / weight of the chain itself. See this thread for an explaination of what the chain # means. EG 530, 525 or 520.
justpucky is offline
post #4 of 16 (permalink) Old 08-21-2006, 04:50 PM
Great idea!
-1 front
+2 rear
520 conversion
X-Ring DiD Chain
Sprocket brand is a debate!
post #5 of 16 (permalink) Old 08-21-2006, 05:23 PM Thread Starter
Great idea!
-1 front
+2 rear
520 conversion
X-Ring DiD Chain
What does this do as far as performance
post #6 of 16 (permalink) Old 08-21-2006, 05:49 PM
Well basically the 520 increases the amount of power you get to the rear wheel by reducing the spinning weight.
The sprocket changes change your gear ratio so that you have more go off the line.
post #7 of 16 (permalink) Old 08-21-2006, 05:52 PM Thread Starter
thanks for the info
post #8 of 16 (permalink) Old 08-21-2006, 10:48 PM
Farely inexpensive to pick up decent acceleration.
post #9 of 16 (permalink) Old 08-21-2006, 11:51 PM
I hate to be the devil's advocate, but there's no free lunch. Acceleration will be quicker, but the 520 chain is slightly weaker than the stock 525 or 530 chain. Other things will decrease by about 10 percent with the sprocket changes. If your mileage is 40 MPG, it will go down to 36. If top speed was 150, it will be 135. If 60 MPH cruise was at 5,000 RPM, it will be 5,500.
post #10 of 16 (permalink) Old 08-21-2006, 11:53 PM
True. I will add that we were doing top speed runs one day and my buddy's '05 GSXR 750 with one up/one down freakin pulled on me bigtime at the top end. His top end was still there bigtime. He was keeping up with a Busa til about 175, then the Busa started to pull, but he was still pulling on me.
post #11 of 16 (permalink) Old 08-22-2006, 01:38 AM
on everything except the strength part. If you get a quality chain. ie.. DiD Gold X ring. The tensile strength is as good or better than most stock 525 0r 530's.
post #12 of 16 (permalink) Old 08-22-2006, 06:21 AM
Great idea!
-1 front
+2 rear
520 conversion
X-Ring DiD Chain
Not to you it isn't.
post #13 of 16 (permalink) Old 08-23-2006, 03:28 PM
True... I know what I believe is the only way..
DiD X-Ring chain
Renthol sprockets
The only way!
While NW is right... you will not notice that much loss on the top end.. not nearly as much from this as you will from getting a speedo healer that corrects that inaccurate speedo!
post #14 of 16 (permalink) Old 08-23-2006, 06:59 PM Thread Starter
cool thanks for the info
post #15 of 16 (permalink) Old 08-25-2006, 01:39 AM
Anytime... you just have to be willing to listen and understand that I'm right!
post #16 of 16 (permalink) Old 08-25-2006, 01:46 AM Thread Starter
