Suspension Definitions & other terminology - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 19 (permalink) Old 08-22-2006, 08:07 PM Thread Starter
TATER's Avatar
I came across this information and it can come in handy when trying to learn about a motorcycles suspension componants, parts, and general biker slang.
SUSPENSION TERMINOLOGY
Have you ever read a magazine test on a new bike and been confused by the words used to describe the bike’s handling? The reason is that suspension terminology is a mixture of engineering and slang words. You should read this chapter before you read any of the chapters on suspension servicing.
ANGULAR MOTIONS
YAW - A motion that veers left or right from the motorcycle’s heading angle.
PITCH - A motion fore or aft, when the front end dives or when the rear end squats.
ROLL - A motion where the motorcycle leans left or right from straight-up riding.
ANTI-SQUAT RATIO - A formula that calculates the relation between the drive sprocket, rear tire contact patch, swinging arm pivot height, and the chain force lines. In order to determine the rear suspension’s characteristic to squatting under acceleration.
AXLE - The spin axis of a wheel.
CHASSIS - The frame, swing arm, suspension, and wheels of a motorcycle.
CENTER OF GRAVITY/MASS CENTER - The center point of the motorcycle’s mass. Normally located somewhere behind the cylinder and below the carburetor of a dirt bike.
DAMPER - A fluid chamber with a means of regulating the fluid flow to restrain the speed of the moving end of the damper during the compression or rebound strokes. A set of forks and a rear shock are considered dampers.
DAMPER SPEED - The relative speed in which the moving end of a damper compresses or rebounds. The two different speeds are high and low.
DAMPING - The process of absorbing the energy of impacts transmitted through the forks or rear shock on the compression stroke, and the process of absorbing the energy of the spring on the rebound stroke.
DAMPING CIRCUITS - There are normally four damping circuits which affect the damper’s speed. There is both a low and high speed circuit for the compression and rebound strokes.
COMPRESSION DAMPING - The damping circuit that absorbs the energy of compression forces on the damper.
LSC - Low Speed Compression damping circuit is affected most when riding through turns.
HSC - High Speed Compression damping circuit is affected most when riding fast over square-edged bumps.
REBOUND DAMPING - The damping circuit that affects the stored energy release of the compressed spring in order to reduce the rebounding speed of the damper.
LSR - Low Speed Rebound damping circuit is affected in the same riding circumstances as LSC.
HSR - High Speed Rebound damping is affected in the same riding circumstances as HSC.
PIVOT - A fixed point at which a lever rotates. Example: swinging arm or suspension linkage.
PRE-LOAD - Pre-load is applied to the fork and shock springs in order to bring the bike to the proper ride height or race-sag dimension. The pre-load can be biased to change the bike’s steering geometry. High pre-load/less sag in the front forks, will make the steering heavy/slow and more stable at high speed.
RAKE - The angle between the steering axis and a vertical line.
STEERING ANGLE - The angle of the handle bars as you rotate them left or right about the steering axis.
STEERING AXIS - The axis where the forks rotate in the frame.
SWINGARM - The rear fork that connects the rear wheel to the frame.
S.A. ANGLE - The angle of rotational motion about the swinging arm pivot axis.
S.A. PIVOT AXIS - The point where the swinging arm mounts to the frame and rotates.
TRAIL - On the front end, the horizontal distance between the steering axis at the road surface, to the tire contact point. Generally forks with off-set axles have more trail than forks with straight through axles.
TRAPPED AIR SPACE - The height of the air space that forms in the top of the fork tube between the fork cap and the oil.
UNSPRUNG/SPRUNG WEIGHT - The unsprung weight of the motorcycle are parts like the wheels, brakes, swingarm and suspension linkage, and the lower front fork legs. The sprung weight is all the parts of the motorcycle that are supported by the suspension.
WEIGHT BIAS - Also called weight distribution. The amount of weight on each wheel of the motorcycle.
WHEELBASE - The distance between the front and rear axle centers.
SLANG TERMINOLOGY
BOTTOMING - A riding situation whereby all the suspension travel is utilized.
CLICKERS - The knobs or screws that control the LSC & LCR circuits of the forks or shock.
STIFF/SLOW SOFT/FAST - These words are used to describe the damping quality of the forks or shock. With regard to the "Clickers", these words refer to the direction of rotation that you will turn the clickers in order to improve the damping. Turning the clickers clockwise will make the damping stiff/slow. Turning the clickers counter-clockwise will make the damping soft/fast.
FLICKING - The action of putting the bike into a full lean position quickly.
FRONT END DIVING - This is what happens when the front forks compress quickly. It usually occurs when braking for turns.
HANDLING - The quality of response from the chassis of a motorcycle, while riding through a variety of obstacles like turns, jumps, hills, whoops and bumps.
HARSHNESS - A word used to describe the quality of the damping.
HEAD SHAKING - A term that describes the high speed oscillation of the forks when braking for a bend at the end of a fast straight-away. Every motorcycle has a certain frequency band when it oscillates. This frequency can be tuned to a higher vehicle speed with a sacrifice in the bike’s ability to turn.
HIGH SIDING - A term that describes what happens when a bike falls to the outside of a turn.
LOW SIDING - A term that describes what happens when a motorcycle falls to the inside of a turn.
HOPPING - Wheel hopping is when the tire bounces up off the ground due to a reaction from a bump.
KICKING - A word often used to describe both "Pogoing" and "Packing".
MID TURN WOBBLE - When the bike wobbles or weaves near the apex of a turn.
PACKING - When the rear shock is compressed by the wheel hitting one bump and cannot rebound quickly enough to absorb the impact of the second or third bump.
POGOING - When the rear shock rebounds so quickly that the rear wheel leaves the ground.
RACE SAG - This term refers to number of millimeters that the forks or shock sag with the rider on the bike in full riding gear. This is essential to proper suspension tuning but is often overlooked or adjusted incorrectly.
REAR END SQUATTING - Squatting occurs when you accelerate the motorcycle. The chain forces push down on the rear wheel. The resultant forces are transferred up the swinging arm into the main frame causing a lifting force which extends the front end causing a weight shift backwards.
COUNTER STEERING - When the rider applies steering pressure in the opposite direction of the turn.
UNLADEN SAG - The number of millimeters that the bike sags under it’s own weight without a rider.
SHOCK FADE - A condition that occurs when the shock oil becomes so hot that it loses it’s transmitability. The damping affect is reduced and the shock compresses easily and rebounds quickly.
SPIKING - A word used to describe how the forks work when the damping is too stiff/slow. This is also associated with "Arm Pump". The feeling in your arms when your forks aren’t absorbing the energy of impacts to the wheel but instead transfer them to your arms.
STICTION - A combination of the words static and friction. This word is used to describe the tension exerted on the moving damper parts by the stationary parts like the bushings, seals, and wipers. Low stiction is desirable because it has less of an affect on the damping.
SPEED WOBBLE - When a motorcycle wavers back and forth rapidly at high speeds.
SWAPPING - When the rear end of the bike pivots around from side to side very quickly.
TANK SLAPPER - When the forks rotate from stop to stop rapidly and your arms and body slap back and forth against the motorcycle’s gas tank.
WASHOUT - A term used to describe what happens when the bike and rider fall to the inside of a turn.
WHEELIE - A word used to describe a motorcycle in motion with the front wheel off the ground.
TERMS USED FOR SUSPENSION COMPONENTS
BASE-VALVE - The compression piston and valving that fits onto the compression bolt assembly.
BLADDER - A closed-end, thick rubber, cylindrical shaped piece that contains the nitrogen gas in a rear shock. The bladder works like an extra cushion on HSC.
BUMPER - A taper shaped dense foam piece that fits on the shock shaft.
BUSHING - A bronze or plastic ring used as a load bearing surface in forks or shocks.
CLEVIS - A fork shaped piece of aluminum used as the bottom mount for most shocks.
DAMPER ASSEMBLY - The parts of a shock comprised of the clevis, shaft, bumper, piston, and shims.
DAMPER ROD - The large diameter aluminum tube in the lower leg of telescopic forks.
NITROGEN - An inert gas used to pressurize the bladder or reservoir of shocks. Some also fill tires with this due to its stability at varying heats.
PISTON - A cylindrical shaped piece of steel with several ports arranged around the periphery so as to direct oil towards the face of shocks.
CLICKERS - The screws or knobs used to fine-tune the low speed damping on forks or shocks.
COMPRESSION BOLT ASSEMBLY - A large diameter bolt that houses the low speed compression adjusting screw and the compression valve assembly.
PISTON ROD - A small diameter steel rod that fits into the upper legs of cartridge forks. It fastens to the fork cap on one end and holds the rebound piston and shims on the other end.
PISTON RING - A ring that fits around the piston and prevents oil from by-passing the piston and shims.
RESERVOIR - A cylindrical shaped device that contains oil and nitrogen gas.
RE-VALVING - A term used to describe a fine-tuning service for altering the compression and rebound shims in order to affect a certain damping characteristic that keeps the motorcycle’s wheels following the terrain in many riding situations
SEAL - A rubber or plastic cylindrical shaped piece that prevents oil from being lost from the damper.
SHAFT - The chrome rod on the rear shock that has a clevis on one end and the piston and shims fastened to the other end.
SHIMS - A thin, steel, round, flat washer used to exert resistance on the oil flow through a piston. A series of shims (valve stack or valving) with varying outer diameters and thicknesses are arranged in sequence to provide a damping affect.
TRANSITION SHIMS - These are shims with very small outer diameters that are used to separate the normal shims of the low and high speed valve stacks.
SHOCK BODY - The aluminum cylinder which contains the damper assembly.
SHOCK DYNO - A machine that cycles a shock absorber at different damper speeds and measures the resistance posed by the four damping circuits.
SPRING - A steel wire that is wound into a coil shape and tempered in order to provide resistance to compression forces and store energy for release to the extended position.
TRIPLE-CLAMP ASSEMBLY - Includes the steering stem-bottom clamp, and top clamp. The triple clamp assembly connects the forks to the frame.
TRANSMITABILITY - This term refers to the suspension oil’s ability to transmit shock loads. As the oil’s temperature rises, the transmitability falls. Example: With every increase in temperature of 18 degrees Fahrenheit the transmitability of the oil falls 50%.
VISCOSITY - A rating system for oils that measures the oil’s flow rate through a fixed orifice at a certain temperature. Also known as the oil’s weight. Example: SAE 30 Wt.
VALVES - A term that refers to a series of shims either for the compression or the rebound damping.
VISCOSITY INDEX - The flow rate characteristic of the oil over a range of temperatures. The VI rating of an oil is directly linked to the oil’s transmitability. Cartridge fork oil has a VI# of 115. Shock oil normally has a much higher average operating temperature so its VI# is 300.
REMBER THOSE WHO ARE NO LONGER WITH US AND KEEP THEM IN YOUR THOUGHTS AND YOUR HEARTS.
post #2 of 19 (permalink) Old 08-22-2006, 08:25 PM
justpucky's Avatar
Sticky please... This will be a continual reference for me.
justpucky is offline
post #3 of 19 (permalink) Old 08-22-2006, 08:32 PM
JK_DILLA's Avatar
good find-
my one line signature
post #4 of 19 (permalink) Old 08-23-2006, 05:11 AM
post #5 of 19 (permalink) Old 08-23-2006, 07:39 AM
post #6 of 19 (permalink) Old 08-23-2006, 10:58 AM
Knight's Avatar
Send a message via AIM to Knight
I'm with pucky, lets make this a sticky. I'm gonna need it through the whole winter while I redo my entire suspension
Knight is offline
post #7 of 19 (permalink) Old 08-23-2006, 06:13 PM Thread Starter
TATER's Avatar
i'm touched, I've been nominated for a sticky... I would like to thank all the little people who were there for me before I became famous... j/k it is not true how they say it was an honor to be nominated... winning rocks.. losing sucks..
I'll try to update it whenever I get some new words and definitions.. feel free to pm me if you have a new term you want me to add to the list..
post #8 of 19 (permalink) Old 08-24-2006, 07:01 PM Thread Starter
TATER's Avatar
hey Gas any chance you can change the title... I originally only had the suspension definitions then I found some of the slang and other stuff... maybe something to the effect of Bike Lingo or Dictionary of bike terminology or how about "the actual name for that thingamajig" or somethin like that???
can you change it?
post #9 of 19 (permalink) Old 08-24-2006, 07:02 PM
What the hey. Its good info!
post #10 of 19 (permalink) Old 08-24-2006, 07:05 PM
can you change it?
What you think?
post #11 of 19 (permalink) Old 08-24-2006, 07:07 PM
justpucky's Avatar
there you go tater... you're own sticky... No you have to police this place and make sure it doesn't turn into a hang-out.
post #12 of 19 (permalink) Old 08-26-2006, 07:22 PM Thread Starter
TATER's Avatar
I THINK THAT I HAVE A FEW WEAPONS LYING AROUND TO WARD OFF WOULD BE S
POST WHORES BEWARE MONTIORED BY HEAVY WEAPONRY
post #13 of 19 (permalink) Old 08-26-2006, 08:41 PM
post #14 of 19 (permalink) Old 08-29-2006, 07:34 AM
post #15 of 19 (permalink) Old 08-29-2006, 09:11 AM
Is this you:
post #16 of 19 (permalink) Old 08-29-2006, 10:00 AM
anyexcus2ride's Avatar
That is some serious hardware
anyexcus2ride is offline
post #17 of 19 (permalink) Old 08-30-2006, 02:26 PM Thread Starter
TATER's Avatar
no... If i was going to act badass I might actually put a clip in the gun...
post #18 of 19 (permalink) Old 02-06-2007, 04:24 PM
Bump.
post #19 of 19 (permalink) Old 02-06-2007, 04:37 PM
YZFR61ST's Avatar
YZFR61ST is offline
