Fuel injector cleaner - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 12 (permalink) Old 08-25-2006, 08:57 PM Thread Starter
Will just any fuel injector cleaner work in bikes or should I be looking out for certain things? Normally I would dump a whole bottle of that stuff in my car but seeing how my tank is only a 4.5 gallon tank would a half a bottle suffice?
ironmannFB3 is offline
post #2 of 12 (permalink) Old 08-25-2006, 09:48 PM
I use FI cleaner only under 2 circumstances...\
1) I bought some bad or contaminated fuel and I want to boost it...
2) I put 1/2 a bottle of 20 gal stuff in when I fill up if I know I am going to burn the tank without stopping...I will put it in if I am going to make a high speed run (90 + MPH)to Panama City (110 miles) or if I am going to blast through the forest where we have an area that is 45 miles of straight hiway (that has just been resurfaced) where I will be running WOT for 20 minutes...
post #3 of 12 (permalink) Old 08-25-2006, 10:21 PM Thread Starter
Your gonna have to tell my why for #2... The reason being I am a recent second owner and I have no idea if he winterized it well.
post #4 of 12 (permalink) Old 08-25-2006, 10:29 PM
I don't know about your bike...but when I run my F4i WOT...it sucks fuel...my mileage drops to 25MPG or less when running 100+ for miles/minutes...When you run that volume of fuel that quickly through the system, I feel you get a better cleaning action...so if I know I will be out blasting...High RPMs for extended periods...I will dump some cleaner in to "flush the system"
Riding around town...I feel it isn't effective and is a waste of money/product
post #5 of 12 (permalink) Old 08-25-2006, 10:35 PM Thread Starter
Thanx for the advice
post #6 of 12 (permalink) Old 08-25-2006, 11:21 PM
this is my first EFI bike but injector cleaning should be similar with cars. I would open up the air box and remove the filter. while the bike is running (on neutral of course) spray the injector cleaner into the intake through the opened airbox. you may need to accelerate to keep it from stalling.
no need to use additives, just routine cleaning once a year.
post #7 of 12 (permalink) Old 08-26-2006, 01:22 AM
the best injector cleaner is sea foam.
post #8 of 12 (permalink) Old 08-29-2006, 11:18 AM
but that won't get the cleaner into the injectors... its not carbed!
Just adjust the ratio and pour the correct amount.
Plus its best to add the stuff at the gas station. Put it into the tank and then fill up. This allows it to mix properly.
post #9 of 12 (permalink) Old 08-29-2006, 03:22 PM Thread Starter
Thank you for that gas man. My eyes kinda went wide when he said spray it into my air box. Anyway, Is there any merit to burining it all at once, or at high speeds to do a more effective job?
post #10 of 12 (permalink) Old 08-29-2006, 05:30 PM
heh, my bad...
dunno why i associated intake port cleaning with EFI cleaning. You all can give me a neg rep on that one.
post #11 of 12 (permalink) Old 08-29-2006, 10:30 PM
Seafoam is the badness
BravoX1 is offline
post #12 of 12 (permalink) Old 08-30-2006, 10:55 AM
No problem. That is a good way... but the only reason is so that the high corrosive make up of the inj cleaner doesn't sit on anything it shouldn't. However, do you think everytime you put a bottle in your car that you go right out and run 400 miles on it to burn it out. NO. Take it or leave it... its your call. I don't think it hurts either way and could see some advantage to Bee's way.
heh, my bad...
No neg pt... just as long as the person asking the question gets the right answer! You are right about spraying it...if its a carb. I've done that before on cars... and you can also do the pour in method to hit it from both sides of the needles!
