gsxr 1000 spark plug problem - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 8 (permalink) Old 08-31-2006, 01:31 PM Thread Starter
one of my spark plugs on my 04 gsxr 1000 keeps fouling out but the other 3 are good.Its always the same spark plug.It runs great after I put a new plug in for about 2 weeks then it fouls out again.
dirtbike25 is offline
post #2 of 8 (permalink) Old 08-31-2006, 02:24 PM
how comfortable are you in disassembling the carburetors. a plug will foul out if it is either getting too much fuel or not getting enough air. if there is a performance issue, a plug can foul out if it is not getting enough spark.
here is a link to show how to read the spark plug for diagnosing problems.
http://www.centuryperformance.com/spark2.asp
post #3 of 8 (permalink) Old 08-31-2006, 02:37 PM
FYI. No carbs in the '04.
post #4 of 8 (permalink) Old 08-31-2006, 03:03 PM
me bad,
this EFI is killing me...
post #5 of 8 (permalink) Old 08-31-2006, 08:57 PM
Can you swap injectors? If the fouling moves to the other cylinder, the injector is bad. If it stays in that cylinder, you could try swapping plug wires with the cylinder that fires at the same time (1 and 4, 2 and 3). If it moves, bad plug wire, if it stays, you may have an oil control problem in that cylinder.
post #6 of 8 (permalink) Old 09-01-2006, 08:31 AM
My guess is that you have an aftermarket exhaust? then you really should buy powercommander and get the right map install.
Or we can just rebuild the carb
Pippi is offline
post #7 of 8 (permalink) Old 09-01-2006, 08:43 AM
you can unplug the harness and check the resistance of each injector. if one is off, then you know it's bad. a simple ohm meter (volt meter) should do.
post #8 of 8 (permalink) Old 09-01-2006, 08:54 PM
Good call!! Rep Pt!
