Gearing the GSXR - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 18 (permalink) Old 09-06-2006, 03:47 PM Thread Starter
Gearing the GSXR
Well lets see here....My bikes gearing is pretty good stock. I mean it will do a stand up in 3rd no problem.....But i was thinking today should i drop one front tooth or raise 2-3 in the rear i know that 3 rear teeth equal 1 front tooth but i have also heard droping one in the front is harder on your chain....Lookin for alittle more acceleration because i know it has to be there...Sure with the gearing now it will do 176 (on the speedo) but who needs to go that fast....Also if i do this is there anyway to correct the speedometer? Cause i would like it to be accurate and i know that gearing throws this off.....Help me out guys.
BravoX1 is offline
post #2 of 18 (permalink) Old 09-06-2006, 03:53 PM
Re: the speedo... double check where your speed sensor is located, on the SV's it's on the front wheel. So gearing changes don't affect the speedo reading. If it isn't a direct sensor to the wheel, then you might need to correct for a gearing change.
justpucky is offline
post #3 of 18 (permalink) Old 09-06-2006, 03:54 PM Thread Starter
You know i'm not real sure but i dont think it reads off of the front wheel like the sv...I'm thinking its in the tranny or off of the front sprocket
BravoX1 is offline
post #4 of 18 (permalink) Old 09-06-2006, 04:14 PM
yeah, last time there was a discussion on the 520 conversion, I checked mine. Just to know.
post #5 of 18 (permalink) Old 09-06-2006, 06:14 PM
Best to see how many teeth are on your stock front sprocket first. If 16 or lower, change the rear sprocket. The lower the number, the tighter the bend, the quicker the chain wears.
But if I had a new Gixxer and wanted more power, I would look at ignition, fuel, and exhaust mods first.
post #6 of 18 (permalink) Old 09-06-2006, 06:53 PM
Power Commander perhaps!
post #7 of 18 (permalink) Old 09-06-2006, 07:00 PM Thread Starter
Exhaust and air filter done. No commander yet.
BravoX1 is offline
post #8 of 18 (permalink) Old 09-06-2006, 07:13 PM
you can always try poker card on the spokes just a little funny
anyexcus2ride is offline
post #9 of 18 (permalink) Old 09-06-2006, 07:23 PM Thread Starter
What are you talkin about?
BravoX1 is offline
post #10 of 18 (permalink) Old 09-06-2006, 08:06 PM
Remember when you were a kid and you cliped a card on your frame so it made noise flippimg through the spokes and you thought it was a great upgrade to your bike because now it sounded like it went faster? just a little joke.
post #11 of 18 (permalink) Old 09-06-2006, 10:10 PM Thread Starter
I got it now.
BravoX1 is offline
post #12 of 18 (permalink) Old 09-06-2006, 10:34 PM
Put a turbo on it.
Astyle is offline
post #13 of 18 (permalink) Old 09-06-2006, 10:46 PM
post #14 of 18 (permalink) Old 09-07-2006, 05:39 AM
You can probly get away with going -1 in the front and +2 in the back w/o problems. Look into a speedo healer.
post #15 of 18 (permalink) Old 09-11-2006, 03:32 AM
speedo healer is a must for changing factory gearing. The sensor is on the countershaft on the new Gixxers. I would go down one on the front first and use that as a gauge to see if you need more. -1 front and 2+ rear is a big change but still acceptable. Anything more than that and the rpms get way crazy trying to ride at highway speeds.
post #16 of 18 (permalink) Old 09-11-2006, 10:25 AM Thread Starter
Link me a speedo healer cause i'm at work but if not i'll get it later.
BravoX1 is offline
post #17 of 18 (permalink) Old 09-11-2006, 10:44 AM
http://www.sporttour.com/motorcycle_...eedohealer.htm
This was the cheapest link on the first full page of google... but still quality product.
post #18 of 18 (permalink) Old 09-11-2006, 11:04 AM
I rode my buddy's '03 ZX6R on the track at Miller and he has -1/+3. It was pretty ballsy. Felt good to me. Didn't really oen it up too much though. I was too busy concentraing on the turns. I'm actually thinking about going -1/+1 on the R6. but I think I'll wait until the current set wears out. by that time, i should have the full system in place with the PC and an added 10hp at least. That might do the trick. we'll see. But definately get a PC for your bike. I'd wear out your stock gearing before you decide to buy new sh*t.
