Tire Sizes???? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 13 (permalink) Old 09-21-2006, 04:36 PM Thread Starter
Tire Sizes????
If a tire model is 185/45R20 what exactly does that mean? can you get the diameter and depth from that? Could someone explain to me what all the different numbers/letters mean.
Ineffable is offline
post #2 of 13 (permalink) Old 09-21-2006, 04:40 PM
185mm wide
side wall is 45% of the tire width
20 is the rim size.
R is for Radial tire.
post #3 of 13 (permalink) Old 09-21-2006, 04:44 PM
Originally Posted by GR_Z750s_rider View Post
185mm wide
20 is the rim size.
I thought the "R" means rim. But it makes sense. If it says "ZR17", that would mean it is capable of Z-rated speeds on the radial tire.
post #4 of 13 (permalink) Old 09-21-2006, 04:49 PM
yep!
post #5 of 13 (permalink) Old 09-21-2006, 04:52 PM Thread Starter
Thanks, one more question, how do you find out the entire diamater of the wheel then, rim and all?
post #6 of 13 (permalink) Old 09-21-2006, 05:11 PM
You talkin outer lip to outer lip? And with the tire mounted?
post #7 of 13 (permalink) Old 09-21-2006, 05:22 PM Thread Starter
Yes, mounted. Across rubber, rim, then rubber if that makes sense.
post #8 of 13 (permalink) Old 09-21-2006, 06:47 PM
185 times .45 =83.5 or about 3.25 inches for the sidewall. So from the bottom of the thread to the rim is 3.25 plus 20 for the rim and another 3.25 to the top of the tire is 26.5 inches. But that's without any weight on the tire.
post #9 of 13 (permalink) Old 09-21-2006, 06:58 PM Thread Starter
Thanks guys.
post #10 of 13 (permalink) Old 09-22-2006, 07:40 AM
20 inch rims? You throwin dubs on your bike? Spinners??
post #11 of 13 (permalink) Old 09-22-2006, 09:01 AM
Isnt there a sticky for tires with ALL of the info ...If not there should be, in the begginers corner would be my best bet.
post #12 of 13 (permalink) Old 09-22-2006, 09:08 AM
not a sticky but I have one ok post and there are a couple more out there too..
https://www.twowheelforum.com/showthread.php?t=11571
post #13 of 13 (permalink) Old 09-23-2006, 01:17 PM
rickmancc's Avatar
185mm wide
20 is the rim size.
rickmancc is offline
