Suspension? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 4 (permalink) Old 09-24-2006, 10:08 AM Thread Starter
Suspension?
I did a search on suspension set up. I found a link Gas Man put up. I not really clear on on a few things. Sorry for the stupid questions
For My 98 ZX9R
I'm 125-130lbs
Lowered .5
1. Front Preload- "3 lines showing" Figured that out. I have 6
2. Front Rebound Damp- "4 clicks out" I'm at 3 out.
3. Front Comp- "8 clicks out"? where do I find front comp? I'm looking at the top of the forks. I thought this location is Front Damp?
4. Rear Preload- "1.25in sag". Is this when I sit on the bike? And do I adjust it with the spring load?
5. Rear Rebound- " 2 clicks out" is this adjustment made at the upper location of the shock? I'm at 9 clicks out.
6. Rear Comp Damp- "12 clicks out" is this adjustment made at the lower location of the shock? I'm at 1 click out.
wingnut is offline
post #2 of 4 (permalink) Old 09-24-2006, 02:12 PM
I believe all your adjustments in the rear are at the bottom. Do you have your owners manual? That would help find what you want...
My link you takl about... are you talking to Sport Rider Thread
If so... set up the bike as it says...
post #3 of 4 (permalink) Old 09-24-2006, 02:13 PM
But he could go a little softer doe to his light weight.
post #4 of 4 (permalink) Old 09-24-2006, 02:28 PM Thread Starter
yep that's the thread I saw. No not a manual to date looking but I have not found one yet, I'm cheep and want to find one on the internet
I'll set it up as it says as a starting point I just have a sick feeling the way it is now is not good what do I know.
I hate to be a PITA can you point me in the rite direction to the above? 3,4,5 and 6
I'll be done after this, I'll leave you all alone
wingnut is offline
