What's all this technical nonsense - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 9 (permalink) Old 10-03-2006, 09:14 PM Thread Starter
I keep reading about "radial" mastercylinders, "radial" calipers, "floating or semi-floating" rotors, "FIXED this, Radial that" And a floating caliper... I dont know if these terms are correct but, that's why I'm asking. Thanx.
-Kevin
post #2 of 9 (permalink) Old 10-03-2006, 09:45 PM
My 'Bolt has a floating front brake rotor. The rotor and the wheel materials expand at different rates, so by being loosely mounted to the rim, the rotor is free to expand and contract as it heats and cools. The purpose is to reduce stress and make the part last longer. This can sometimes cause a clicking to occur when the brakes are applied, which is normal. Mine did it at parking lot speeds during break-in, but not so much since new.
L48Shark is offline
post #3 of 9 (permalink) Old 10-03-2006, 09:52 PM
Take a look at this...Pretty good site for explainations
http://www.motorcycle.com/mo/mcnuts/...s02_1009.motml
And look here too...
http://www.motorcycledaily.com/13nov...ialbrakes.html
post #4 of 9 (permalink) Old 10-03-2006, 09:52 PM
I Googled radial brakes and found this. Put simply, radial calipers are mounted at both ends, which reduces the chance of pad misalignment. Makes sense. And here is a discussion on master cylinders.
L48Shark is offline
post #5 of 9 (permalink) Old 10-03-2006, 09:55 PM
...if you pony up for the subscription.
L48Shark is offline
post #6 of 9 (permalink) Old 10-03-2006, 10:00 PM
Education ain't free...
post #7 of 9 (permalink) Old 10-03-2006, 10:24 PM
There are other sources. However, that is a good website. I enjoyed their reviews before they went subscription based.
L48Shark is offline
post #8 of 9 (permalink) Old 10-03-2006, 10:53 PM
some of it is. usually the lessons you DONT want are free.
post #9 of 9 (permalink) Old 10-09-2006, 07:43 PM
