f4i clutch installion - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 12 (permalink) Old 10-05-2006, 06:21 PM Thread Starter
rickmancc's Avatar
Hello,
I have a simple question that should be easy. I was replacing the clutch on an 01 f4i today with the oem 03-06 rr clutch same oem part# not my first or second time replacing the clutch, but when I reinstalled the clutch cover, the clutch actuator seems like its not pulling the pressure plate, so I tok it all back apart and for *****s I re installed the old clutch and the same problem, is that correct? I am I missing something I have the factory manual and installed the plates in the correct order. but I should still notbe able to mover the actuator so easily with only the return spring giving me pressure. Let me know if any1 has ran across this issue.
Thanx 4 ur reply!
rickmancc is offline
post #2 of 12 (permalink) Old 10-06-2006, 09:40 AM
post #3 of 12 (permalink) Old 10-09-2006, 09:04 PM
BUMP!
I have no idea but its interesting...
post #4 of 12 (permalink) Old 10-10-2006, 02:45 AM
Check the basket and make sure it hasn't broken.
post #5 of 12 (permalink) Old 10-11-2006, 04:01 PM Thread Starter
rickmancc's Avatar
so far I found the plates to be a different heights so I ordered a barnett I will install it tonite, the basket is all ok
post #6 of 12 (permalink) Old 10-12-2006, 03:40 PM
post #7 of 12 (permalink) Old 10-14-2006, 10:09 PM Thread Starter
rickmancc's Avatar
figured that the oem 600rr is not compaitable with the 01-03 f4i clutch the barnett clutch linked up ok
post #8 of 12 (permalink) Old 10-15-2006, 01:52 AM
So the Barnett didn't work either?
post #9 of 12 (permalink) Old 10-16-2006, 09:37 AM
NO I think he's saying the F4i replacement by barnett worked fine. Just that the 600RR stuff don't work on the f4i.
post #10 of 12 (permalink) Old 10-19-2006, 12:47 AM Thread Starter
rickmancc's Avatar
thanx 4 clearing that up gasman , that is what i meant
post #11 of 12 (permalink) Old 10-19-2006, 06:28 AM
post #12 of 12 (permalink) Old 10-20-2006, 02:14 AM
No problem Rick.... glad to help..
