HELP! R1 Ignition switch removal. - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 9 (permalink) Old 10-08-2006, 01:39 PM Thread Starter
R1HOOLIGAN's Avatar
Anyone ever removed the ignition switch on an '04-'06 R1? I am putting on a Vortex triple clamp and need to remove the ignition switch from the OEM triple clamp. The bolt heads holding it on are just smoothe "domes". How the &^%# do you get them off??? Thanks for any suggestions.
R1HOOLIGAN is offline
post #2 of 9 (permalink) Old 10-08-2006, 01:46 PM
I'm pretty sure you have to drill them out. The pop rivet new ones in.
post #3 of 9 (permalink) Old 10-08-2006, 03:08 PM Thread Starter
R1HOOLIGAN's Avatar
Figured it out. It's 2 allen head cap bolts that have the hole filled in after installation to prevent theft (I assume). Anyway, drilled the heads off and it came off. What a royal PIA!
post #4 of 9 (permalink) Old 10-08-2006, 03:21 PM
Good to know. Its supposed to be a PITA.
post #5 of 9 (permalink) Old 10-08-2006, 03:46 PM
Personally...I would have suggested a slide hammer and toggle switch when the owner was away.
post #6 of 9 (permalink) Old 10-08-2006, 10:00 PM
Actually they are breakaway bolts. The bolt head breaks off when it hits the proper torque making it difficult to remove.
post #7 of 9 (permalink) Old 10-09-2006, 08:41 AM Thread Starter
R1HOOLIGAN's Avatar
I had never heard of that, but you can sure see that's what it is (or was in my case). Learn something every day....even at my age
post #8 of 9 (permalink) Old 10-09-2006, 09:49 AM
Post pics of the new triple.
post #9 of 9 (permalink) Old 10-13-2006, 09:30 PM
and you could have welded a bolt or nut to the end then and spun it out that way too!
