2002 Gixxer prob - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 26 (permalink) Old 10-08-2006, 07:52 PM Thread Starter
2002 Gixxer prob
My 2002 gixxer 1000 is giving me a problem, sometimes not always, when i open up the throttle the bike just "cuts off" like the rpm would be 9000 it would just go to Zero then back up again. I checked the fuel pump thinking maybe fuel starvation at high rpms but the fuel pump was okay. I am thinking maybe it could be the spark wires or the magnet.
Any ideas of what it could be?
post #2 of 26 (permalink) Old 10-08-2006, 09:57 PM
You might want to check out the tip-over safety switch.
post #3 of 26 (permalink) Old 10-09-2006, 01:07 AM
I agree. Something is cutting off your ignition. I would start with the safety switches, like the kickstand switch, tip-over switch, etc.
post #4 of 26 (permalink) Old 10-09-2006, 01:53 AM
and make sure the kill switch isn't hung 1/2 way. If the bike has been crashed and the previously mentioned items seem ok. The check for chafed wires in (the kill switch housing), ignition switch (key) around or to all switches and ECM.
post #5 of 26 (permalink) Old 10-09-2006, 06:59 AM
post #6 of 26 (permalink) Old 10-09-2006, 12:47 PM Thread Starter
Cool
Thanks for the tips, i dont think it is the kill switch, but the side stand sensor is ringing some bells, i will look into it and let you know if i find anything
post #7 of 26 (permalink) Old 10-09-2006, 04:08 PM
I would think that this may be the kickstand switch, and is posssible that it actually is too. if its a random, and unpredictable thing, then yeah, I'd suspect it.
post #8 of 26 (permalink) Old 10-09-2006, 10:18 PM
You might be surprised what can be seen sparking in a dark garage!
post #9 of 26 (permalink) Old 10-11-2006, 07:31 PM Thread Starter
Thanks alot guys, it was the kickstand switch, I just took a piece of rope and tied the kickstand to the footpeg and no powercuts, i removed the rope and yeah..powercuts, so am gonna see about replacing it.
Thanks for all the help!
post #10 of 26 (permalink) Old 10-12-2006, 09:47 AM
Maybe the spring is weak.
post #11 of 26 (permalink) Old 10-12-2006, 10:57 AM
The switch maybe loose. Some are even adjustable. Adjustments may need to done on the kick stand too. I've had to do that after a crash.
post #12 of 26 (permalink) Old 10-12-2006, 12:40 PM Thread Starter
Yeah it is the Spring, but guess what, lol.. its not available
Now my radiator is overheating..lol ..looks like its gonna be an expensive month
post #13 of 26 (permalink) Old 10-12-2006, 12:55 PM
That's odd. Years of ridding and many bikes. I've never had that problem.
post #14 of 26 (permalink) Old 10-12-2006, 01:04 PM Thread Starter
Cool
I guess coz its the heat we have here, I mean our summer's we talking about high 40's (i think 120F more or less) Our winters we reach a minium of like 10C or 9C no less, plus because we are on an Island, we have the humidity factor, sometimes like the past few nites we have had humidity at 80% Taking all these aspects and more does take its toll on parts that normally do not run out easily.
For Example sometimes we have sandstorms, so having a K&N airfilter for 3-5years is good, unlike it says on the box 10yrs or 100000kms, we cannot really do that here.
I checked and re-checked, then i took it to the agent and the mechanic looked at it and said, Radiator needs replacing, i guess i went so he could prove me wrong.. wishful thinking
post #15 of 26 (permalink) Old 10-12-2006, 01:18 PM
IDK what to say about the spring other than try your local hardware store or specialty nuts and bolts supplier. As for the rad, I would flush it (several times if needed) Unless its severely damaged.
post #16 of 26 (permalink) Old 10-12-2006, 01:21 PM Thread Starter
What's IDK mean?
post #17 of 26 (permalink) Old 10-12-2006, 01:26 PM
What's IDK mean?
I Dont Know.
post #18 of 26 (permalink) Old 10-12-2006, 01:35 PM Thread Starter
I Dont Know.
Lol, sorry, my bad...
I guess ill try the flushing part but i dont think it will work as i patched up the Radiator a few months ago as it was leaking water.. I should have waited on ordering the busa parts.. oh well..
post #19 of 26 (permalink) Old 10-12-2006, 01:39 PM
Its always fun trying to maintain several bikes at once. I usually make a whole day of it and do the little jobs on all three on the same day.
post #20 of 26 (permalink) Old 10-12-2006, 01:42 PM
Wow man, it's coming down on you all the sudden. w/ the fix.
