Coolant - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 27 (permalink) Old 10-10-2006, 12:38 PM Thread Starter
Coolant
water + redline vs Ice
Here's my comparison.
redline water wetter + water outperformed the stock antifreeze. I compared it with my daily commute to work. Idling at the light, the temp didn't hit past 215 F. (ambient is over 95 F). It cools down very quickly. 15 Degrees in less than two blocks.
I switched over to Engine Ice in the beginning of October. The weather is much cooler and less humid. Sitting at the same light with ambient at 80 F. the engine temp hits 220 F with fan kicking on. Temp cools 10 degrees in less than two blocks. There was still residual water + redline in the system so I'll flush that out next week with more Engine Ice (expensive stuff). I believe Ice is not a water based product. So far, I think redline is better. But I'll give Ice a few more weeks then I'll switch back to redline and compare results again.
note: redline + water does not have anti-freeze.
my next project in 2007 is converting to DOT5.
post #2 of 27 (permalink) Old 10-10-2006, 01:26 PM
This time of year. Or cold months. Depending on where your at. Bikes need antifreeze unless the bike is being stored in a climate controlled environment.
Keep us posted on your findings. I recently switched to ICE from Redline. It was an availability issue and not a dislike of product.
post #3 of 27 (permalink) Old 10-10-2006, 01:29 PM
My cooling system consists of 4 qts of 10w40
post #4 of 27 (permalink) Old 10-10-2006, 01:48 PM
rep points
post #5 of 27 (permalink) Old 10-11-2006, 09:52 PM
Me too now!
But due to the weather/storage situation I have always done the Ice!
For record... I have found that Ice does about 20 degrees less than standard anti-freeze
post #6 of 27 (permalink) Old 10-12-2006, 07:10 AM
Me too now!
But do you have a big azzed oil cooler on your rig?
post #7 of 27 (permalink) Old 10-12-2006, 08:02 AM
Nope... don't need one on my setup. I don't have fairings restricting air flow.
post #8 of 27 (permalink) Old 10-12-2006, 08:20 AM
Oh well...who cares. Oil coolers unite!
post #9 of 27 (permalink) Old 10-12-2006, 09:12 AM
Nice comparison. rep'd ya. I've been trying to figure out what I wanted to switch to, Ice sounds like the way to go in MI. Do most tracks allow Ice or do I need to get some Wetter for that?
Knight is offline
post #10 of 27 (permalink) Old 10-12-2006, 01:33 PM
That's debatable. The look trick on choppers and HDs Nobs always ask if their nitrous bottles.
post #11 of 27 (permalink) Old 10-13-2006, 09:07 PM
No if you go Ice... you run just that. But you will need 2 bottles. It takes just over 1 bottle. Furthermore, you will need to rinse out the system with distilled water at least 3 times... the rinse will take like a 2 gal thing of cheapy distilled water.
Yeah but all it does for me is make me replace more oil.
post #12 of 27 (permalink) Old 10-14-2006, 12:30 AM
EIDROEDYR's Avatar
Can you keep Engine ICE in your bike throughout the winter?
EIDROEDYR is offline
post #13 of 27 (permalink) Old 10-14-2006, 04:40 AM
post #14 of 27 (permalink) Old 10-14-2006, 08:15 PM
Yes... that's whay you want it over the water & water wetter.
post #15 of 27 (permalink) Old 10-15-2006, 02:55 AM
It only has antifreeze capabilities. It should be fine if bike is stored in a garage that barely droops below freezing.
post #16 of 27 (permalink) Old 10-16-2006, 09:39 AM
It only has minimum antifreeze capabilities. It should be fine if bike is stored in a garage that barely droops below freezing. If its stored in a cold climate in a shed or the like. I would drain and replace with antifreeze for the winter.
And that is the PIA that you will avoid with the Ice. Trust me... the Ice rocks!!!
post #17 of 27 (permalink) Old 10-16-2006, 01:29 PM
I will have to check to verify but I thought the ICE was limited in freeze protection.
post #18 of 27 (permalink) Old 10-16-2006, 01:38 PM
I was wrong and will be the first to admit it. I pulled this info straight from thier site here
Engine Ice Hi-Performance Coolant TM offers excellent alloy protection for Motorcycle engines against corrosion, overheating, & freezing. Engine Ice Hi-Performance Coolant TM is pre-mixed at a 1:1 ratio with de-ionized (DI) water and has a boiling point of 256oF and a freezing point of -26oF. Propylene glycol engine coolants will perform superbly under most operating conditions and will not affect factory warranty coverage.
post #19 of 27 (permalink) Old 10-17-2006, 12:38 AM
Yep... like I said... perfect!
post #20 of 27 (permalink) Old 10-17-2006, 08:05 AM
You DO NOT what to use DOT 5 in you bike. You want to use DOT 5.1
Unlike polyethylene glycol based fluids it is not hygroscopic, however this means that instead of being dissolved, any water in the system will eventually find its way to the lowest point in the brake line, corroding it, and potentially boiling and causing brake failure. Because of this, and other reasons (such as compatibility, cost, and lack of advantage over regular fluids) it is no longer used very much. Use DOT 5.1
Pippi is offline
