636 throttle lag - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 29 (permalink) Old 10-18-2006, 04:17 PM Thread Starter
636 throttle lag
when u have the throttle fully open...it bogs it self down at like 5 6 grand....then it will go up to 7 or 8 then jumps to 12 grand and then repeats itself over and over again....so i was wondering on how to fix this problem...
thankz......
Shawn Bartlett
05' ninja 636.....love it......
SMFB636 is offline
post #2 of 29 (permalink) Old 10-18-2006, 04:43 PM
Some of you Kawi guys help him out!
post #3 of 29 (permalink) Old 10-18-2006, 05:17 PM
The suzuki i have does it on the change from small to large injectors. could be that i dont think they have dual injection tho and
BravoX1 is offline
post #4 of 29 (permalink) Old 10-18-2006, 06:23 PM
have you got any modifications on the bike? exhaust, power commander? if you do, that MAY be the source of your problem. sounds like a lean condition at certain RPM.
post #5 of 29 (permalink) Old 10-18-2006, 07:34 PM Thread Starter
well i have a yosh rs-5 pipe and a power comander on it....but when i first bought it...there was no problems it ran great....then the butterfly exhaust vavle blew...so i bought a new one...and ever since then...its been going down hill.....could it be that i need my vavles adjusted...or my timing...or what.... ....... for ur time.....
Shawn Bartlett.....thankz
SMFB636 is offline
post #6 of 29 (permalink) Old 10-18-2006, 08:20 PM
How many miles?
I suggest taking the PC out of the loop and go from there.
When you replaced the exhaust vlv are you sure the sensor is functioning correctly?
post #7 of 29 (permalink) Old 10-18-2006, 08:31 PM Thread Starter
theres like almost 12,ooo miles........well i didnt change the exhaust vavle i took it in and had it done.....like i see it moving when i play with the throttle.....i did take the power commander off and there is no change in what it does.......so......
Shawn Bartlett......thank u for ur time......
SMFB636 is offline
post #8 of 29 (permalink) Old 10-18-2006, 09:13 PM
Are you getting FI codes on the dash?
post #9 of 29 (permalink) Old 10-18-2006, 09:16 PM Thread Starter
no...it did when the exhaust vavle went.....but yeah...everybody i've talked to said they never expierenced this before so.........
SMFB636 is offline
post #10 of 29 (permalink) Old 10-18-2006, 09:39 PM
I had problems with mine not throttleing up fast enouf, very show on take off. my friend loosen my safety cable up that cuts the throttle off when u let go to the throttle. That really help my bike i dont know if it was in a bind or what but it really help me. i have a ZX6RR 03. Good luck sir with fixing it
But it almost sounds like its miss fireing at that RPM, like i could be a CPU problem.
FcarsBuyABike is offline
post #11 of 29 (permalink) Old 10-18-2006, 10:37 PM
That's actually a good call!
post #12 of 29 (permalink) Old 10-19-2006, 02:50 AM
and should be easy to diagnose by having a Kawi shop test it.
post #13 of 29 (permalink) Old 10-19-2006, 10:13 AM
It sounds like when they installed the new exhaust valve they didnt adjust it to the thottle. I know one on the GSXR if you dont just it right, when you open her up and the valve doent open @ the same it bogs because the exhaust has no where to go.
You gut the valve and then by-pass it on the computer.
Pippi is offline
post #14 of 29 (permalink) Old 10-19-2006, 07:08 PM
my Z28 had almost the same problem laggy around at 4,000 rpm, gas MPG is very bad i mean like 13 MPG. Me and a friend change the spark plugs out. #8 had so much carbon on it it wasnt even fireing at all. its the last one on the passenger side the hardest one to do with out a lift or tilling the engine back.but after that i went to 22 MPG. i agree with the takeing it by a kawasaki shop. the testing machine make take some $$ but it will good just to know.
post #15 of 29 (permalink) Old 10-20-2006, 01:03 AM
And that may even be a better call! REPT!
post #16 of 29 (permalink) Old 10-21-2006, 05:24 PM Thread Starter
but this all of sudenly started this... it ran pretty ok after they installed it...but the last couple of times i took it in to get checked out....its been doing this...so i was thinking it was in the vavles.....
so thankz for ur time....
SMFB636 is offline
post #17 of 29 (permalink) Old 10-22-2006, 11:56 PM
Where in MI are you? and what dealership/shop have you been taking it to?
post #18 of 29 (permalink) Old 10-23-2006, 04:23 AM Thread Starter
im from clinton..and i have been taking it to powersports in adrian.....and it seems to be get worse every time i take it in....
SMFB636 is offline
post #19 of 29 (permalink) Old 10-23-2006, 05:10 AM
OK... don't know much good or bad about them.... I'm in the downriver.
post #20 of 29 (permalink) Old 10-23-2006, 10:11 AM Thread Starter
well there ok...but they run everything ****ty....but its were i bought the bike from and was the around the best priced to get everything done at...but now i have learned my leason.....
SMFB636 is offline
