gsxr 2002 question - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 6 (permalink) Old 10-28-2006, 09:14 PM Thread Starter
gsxr 2002 question
i have a 2002 1000 gsxr i put a pipe on it now my oil light is on what do i need to do to fix this problem. thank you for your time
hulsey is offline
post #2 of 6 (permalink) Old 10-28-2006, 10:22 PM
Put black tape over the light. Worked when my brake light wouldnt go off on my car !!!!!
pocketrocket is offline
post #3 of 6 (permalink) Old 10-29-2006, 12:15 PM
fastnotch2002's Avatar
Get rid of the junk and buy a Yamaha!
J/k I would try to find out what the problem, maybe just a faulty sensor or low oil pressure?
fastnotch2002 is offline
post #4 of 6 (permalink) Old 10-30-2006, 08:10 PM
Moved to tech help section with a hyper link in the Suz section.
Do you know if you are getting oil pressure?
Have you check your oil pressure sensor?
post #5 of 6 (permalink) Old 11-01-2006, 02:04 PM
You have obviously removed the "SETS" system or "EXUP", you need to disconnect the wire in ur EMS (the white one ) and put tape around it. As now the EMS is not getting information from that unit.
post #6 of 6 (permalink) Old 11-01-2006, 02:41 PM
my memory of it is real dim,if you do a search online u should find it in detail and with pix..easy to do. i tried but i have to get off the pc now, if u didnt find it let me know and ill get it for u when i get back
