engine dies when trying to put it in gear? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 8 (permalink) Old 11-10-2006, 07:55 PM Thread Starter
Exclamation engine dies when trying to put it in gear?
what up guys i just got a 93 cbr f2 . i bought for a guy and it didn't run. he said the spark plugs fouled out. so today i replace it and it fired right up! i then tried to take it out for a test ride and as soon as i put it in to first gear it just died( stoped running). i then put it in nuetral and started it again. this time i tried to put in 2nd gear. it died again.
any takers onwhat it might be? any info would help thank you ..
clean929 is offline
post #2 of 8 (permalink) Old 11-10-2006, 08:04 PM
just to get the obvious ones out of the way...
is the bike warm? is the choke on? is the kickstand down?
I'm sure you'll get some better answers soon enough!
post #3 of 8 (permalink) Old 11-10-2006, 08:11 PM
Kickstand switch... I'm 90% sure...
post #4 of 8 (permalink) Old 11-10-2006, 09:40 PM Thread Starter
kick stand is up. no kick stand switch wire found.. i got it .. it was sitting for a while i think the clitch plate may have gotten stuck together .. all i did was put it on the rear stand, started it got it up to about 5k rpms and shift it into gear.. it then begain to run. i then took it up and down the street and it shifts fine..
thanks to all!
clean929 is offline
post #5 of 8 (permalink) Old 11-10-2006, 10:00 PM
thanks to all!
glad I couldn't help... rep yourself...
post #6 of 8 (permalink) Old 11-10-2006, 10:11 PM
That woulda been my guess as well... but either way, glad it sounds like it's solved!
neebelung is offline
post #7 of 8 (permalink) Old 11-11-2006, 12:25 AM
No doubt.... oh well.... like Tater said... glad we were no help!
post #8 of 8 (permalink) Old 11-13-2006, 04:16 PM
another problem solved.
