help on bleeding brakes - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 6 (permalink) Old 11-23-2006, 09:44 PM Thread Starter
I have changed the brake lines on my 06 gsxr 1000 i need help bledding the air out. any help hint's
hulsey is offline
post #2 of 6 (permalink) Old 11-24-2006, 05:10 AM
pump pump pump...HOLD. Bleed at the caliper, the master cylinder and the banjo's. Dont let the fluid get too low...that will allow more air into the line. Get a friend to help and dont get any fluid on pain or your rotors/pads.
post #3 of 6 (permalink) Old 11-24-2006, 06:04 PM
fastnotch2002's Avatar
use a Mity-vac, take 10min to do all the brakes!
[SIGPIC][/SIGPIC]
2004 Yamaha R1
2005 Wide tire Busa LE
Custom built chopper
fastnotch2002 is offline
post #4 of 6 (permalink) Old 11-25-2006, 04:04 AM
Don't let ANY fluid get on ANYTHING!!
post #5 of 6 (permalink) Old 11-25-2006, 09:12 AM
Did you get them bleed?
post #6 of 6 (permalink) Old 11-26-2006, 09:09 PM Thread Starter
yep
yes i did thank's for the help!!!!!!
hulsey is offline
