front brake lock up what is wrong? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 26 (permalink) Old 11-24-2006, 09:47 PM Thread Starter
ok well i put new brake lines on my 06 gsxr 1000 i bled them like i was told on my other thread i was riding the bike about 10 miles and all of the souden the front brake lever got hard and the bike was locked on the front.I used a wrench on the bleeder valve on the left fluid came out ok now what is up!!!
hulsey is offline
post #2 of 26 (permalink) Old 11-24-2006, 09:56 PM
sounds dangerous but i can offer you no solution.
post #3 of 26 (permalink) Old 11-24-2006, 11:22 PM
Something clogging the system, like a piece of flash stuck in the line?
post #4 of 26 (permalink) Old 11-24-2006, 11:33 PM
also what kind of brake fluid did you use? i just wanna know.
post #5 of 26 (permalink) Old 11-24-2006, 11:35 PM Thread Starter
fluid
dot 5
hulsey is offline
post #6 of 26 (permalink) Old 11-25-2006, 11:54 AM
Looks like JK hit the nail on the head. DOT 5 silicone won't mix with DOT 3 or 4. Get a quart of Valvoline SynPower brake fluid and flush out the master cylinder, lines and calipers.
post #7 of 26 (permalink) Old 11-26-2006, 12:00 PM
post #8 of 26 (permalink) Old 11-26-2006, 08:12 PM Thread Starter
that's it!!!
well that is what i did thank you for the help i flushed it with silocone ok now
hulsey is offline
post #9 of 26 (permalink) Old 11-26-2006, 09:29 PM
Sweet, good thing you didnt putter down. Brake probs suk
stomper173 is offline
post #10 of 26 (permalink) Old 11-27-2006, 08:54 AM
husley that had to suck... do all that work just to have to do it all over again!
post #11 of 26 (permalink) Old 11-27-2006, 11:21 AM
buy a mityvac and flushing/changing/bleeding brakes is a 20 minute effort for both systems...
post #12 of 26 (permalink) Old 11-28-2006, 12:13 AM
How much cheddar?
post #13 of 26 (permalink) Old 11-28-2006, 07:05 AM
I bought my mityvac online from a place in Tampa for under 35 bucks...I got it priority mail the next day...
post #14 of 26 (permalink) Old 11-29-2006, 01:13 AM
Nice. What exactly does it do?
post #15 of 26 (permalink) Old 11-29-2006, 08:56 AM
The mityvac is a suction device. You connect the tube to the caliper...open the master cylinder...squeeze the handle a few times to create vacuum...break the bleeder open and it "sucks" the fluid from the system. keep squeezing the handle and you can empty the reservoir, lines, calipers, everything in seconds.
If you are changing the fluid...as the reservoir runs out, start adding the new fluid...keep squeezing and adding fluid until it runs clean and clear with no bubbles...close the bleeder, top off the MC and you're done...
When we installed the SS lines on birdman's SV...we used the mityvac to completely drain his system. we removed the old lines and calipers without spilling a drop.
We even put the calipers on the compressor and blew all the sludge and "gravy" out.
Then we re-mounted the calipers...dry...and installed the new lines...dry.
Then we hooked the mityvac up and "sucked" the new fluid through the system in seconds...a few pumps of the lever/pedal...sucked some more fluid through and eliminated all the air...topped off the MC's and he was riding the bike in less than an hour from when we started...
post #16 of 26 (permalink) Old 11-30-2006, 05:25 AM
Sounds like a great piece of equipment. When I swaped lines on my buddys ride it took us all of 3 hours to do front and rear. Most of that bleeding.
post #17 of 26 (permalink) Old 11-30-2006, 06:40 AM
If we had spent 3 hours on birdman's brakes...we'd have spent more on the beer than I did for the mityvac...
post #18 of 26 (permalink) Old 11-30-2006, 05:23 PM
ive had a mityvac for about a year now and keep forgeting i have it, untill after all the bleeding is done. way to go me!
post #19 of 26 (permalink) Old 11-30-2006, 11:08 PM
Ouch.
post #20 of 26 (permalink) Old 11-30-2006, 11:24 PM
brakes are no joke...
YZFR61ST is offline
