Smoke out the exhaust - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 20 (permalink) Old 10-25-2004, 10:29 AM Thread Starter
I have an '03 GSXR 1000 with about 3,000 miles on it and have recently noticed smoke coming out of my pipe when I first start it up and rev it. And once after a long ride I stopped and turned it off and smoke consistently came from my pipe for about 30 seconds. What's goin' on???
Also, I put on a Yosh half-system w/ a K&N Airfilter...do I need to re-jet my bike? Or do anything else? Thanks for the help.
Ryan
sherwood is offline
post #2 of 20 (permalink) Old 10-25-2004, 10:31 AM
What kinda of oil?
post #3 of 20 (permalink) Old 10-25-2004, 10:48 AM
Mine smokes when it getss really hot. Sometimes when I road it real hard and put it away right after.
post #4 of 20 (permalink) Old 10-25-2004, 12:42 PM
It's a GSXR isn't it?!? Don't worry about it, it is just eating itself from the inside out! J/K!!!!
Do you ride it hard...really? Do you park it outside? Stock can? You wouldn't be so lucky to have bought a extended warrenty?!?
Maybe Larry will have some insight!
post #5 of 20 (permalink) Old 10-25-2004, 01:23 PM
Its not a big deal. Its either mosture or too much oil or somthing EZ.
post #6 of 20 (permalink) Old 10-25-2004, 01:55 PM Thread Starter
I have whatever the factory put in after my first oil change. So I'm not too sure exactly what's in there. My first and only thought is that it has to be oil leaking somewhere...so where could this be coming from...it's brand new!!! Only 3K miles on it. It's still under the 1 year warranty so maybe I should get it checked out...
Would changing my oil again help it? What oil do you guys recommend?
sherwood is offline
post #7 of 20 (permalink) Old 10-25-2004, 01:57 PM
Its under warranty still. Don't stress it. Take it to them and let them find it and fix it.
And welcome to TWF. Be sure to sign in to the newbie thread.
GSXR1000DJ is offline
post #8 of 20 (permalink) Old 10-25-2004, 03:26 PM
I'm with DJ!! You're wastin too much time talkin about it. Just take it to the dealer and let them figure it out!!
post #9 of 20 (permalink) Old 10-31-2004, 12:15 AM
OK, relax a second here. First of all, have you checked your oil level and are you loosing any? Second, if it is smoking out the end of the pipe, you probably are not leaking it there, it is coming from the motor. Third, what color/smell does the smoke have?
Also take into account that most aftermarket exhaust systems will smoke the first couple of times you ride with them installed and sometimes need a good hard run to burn off the oils from production. In addition, your combination of the pipe and air fliter could have you running lean causing the pipe to get hotter than normal and burning off some of the packing material.
One other thing, don't rev the bike when you start it. Let it warm up a little before you get on it.
post #10 of 20 (permalink) Old 10-31-2004, 12:36 AM
and the voice of reason finally kicks in ...thanks larry!
word the wise too about that letting the bike warm up...take it from experience..
Need4Speed is offline
post #11 of 20 (permalink) Old 10-31-2004, 01:17 AM
cerveja's Avatar
Send a message via Yahoo to cerveja
Ryan
DUUUHHHHH!!! It's an exhaust pipe!! It's not the fountain of youth!!! What did you expect would come out of? Apple Cider? French Perfume? Maple Syrup?
Sorry, Couldn't resist. Othen then my obvious intuition, Larry has you covered. Need to know what color, very important. Theroize all you want, but it's under warranty so F'it, it's winter time, let the dealership screw with it.
It Doesn't take an Idiot to be a Brain Surgeon
cerveja is offline
post #12 of 20 (permalink) Old 10-31-2004, 01:21 AM
Nicely put there cerveja. Now all you have to do is post more.
post #13 of 20 (permalink) Old 10-31-2004, 02:03 AM
we have a thread for that kinda crap now!!
post #14 of 20 (permalink) Old 10-31-2004, 06:58 AM
Got to love Dyno takin my job and pointing out the obvious!! Thanks man!!
post #15 of 20 (permalink) Old 10-31-2004, 10:22 AM
Burning coolant smells like maple syrup.
Mojo is offline
post #16 of 20 (permalink) Old 10-31-2004, 10:48 AM
it does? never realized that.. wonder if it tastes the same too!
post #17 of 20 (permalink) Old 10-31-2004, 10:54 AM
post #18 of 20 (permalink) Old 10-31-2004, 11:07 AM
first off, I didnt jack this thread, so you can take that thread highjack stuff and stick it somewhere else...
post #19 of 20 (permalink) Old 10-31-2004, 11:44 AM
There you go still...
post #20 of 20 (permalink) Old 10-31-2004, 11:56 AM
you really need to put down the sippy cup and play toys ..
