Simple Guide to engine noises - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 36 (permalink) Old 12-25-2006, 12:14 AM Thread Starter
NOTE: Take into account that not all engine noises are abnormal and may be actually considered normal by the manufacturer please check before making asumptions!
Right this is a guide that will guide you with engines noises and what the possible causes maybe! Also make a note of the condition the motor is in when reproducing the noise!
TOP END NOISES
Ticking ---> Low to high RPM's hot or cold ---> Valve adujustment, bent valve/ valve seat. Excess valve stem to valve guide clearence
Ticking ---> Low to high RPM's hot ---> excess pad to lifter clearence, Lifter shape, lifter-to-cylinder head clearencem worn camshaft lobes/rocker arms
Ticking/Clatter ---> Idle to mid-range, hot or cold ---> loose cam chain
Clatter ---> Primarily at idle, hot ---> Camshaft end play
Knocking ---> Idle to mid-range, hot or cold ---> Camshaft end play thrust clearence. Loose cam sprocket bolts
Rattle/slapping ---> Idle to low speed, Primarily hot ---> excessive piston-to-cylinder clearence
Rattle/Pinging ---> Mid to high range, under load, hot --> Detonation
Bottom End Noises
Knocking ---> Idle to mid-range or specific RPM, hot or cold --> loose exhaust system or broken internally
---> Accelerating, decel, hot or cold ---> Loose primary chain, primary drive gear nut
---> Primarily at idle, hot or cold ---> Crankshaft end play
---> Idle to mid-range, primarily hot ---> Improper rod bearing
---> Idle to mid-range, under load, hot ---> excess main bearing clearance
Rattling ---> Idle to mid-range, hot or cold loose cam chain
Chattering ---> Low to mid-range shifting under load ---> worn friction plates or clutch housing
Whirring ---> All speeds, Primarliy hot ---> worn main bearings
Tick or Clunk ---> Low to high RPM's, one or more gears, hot or cold ---> Transmission
Howling,grinding,squealing ---> low to high RPM's under load, all gears, clutch in or out, hot or cold ---> Improper tooth contact, Improper backlash in primary, middle or final drive gear!
Remember! the conditions stated here will not always apply to your bike but might always be the same problems, and the problems stated are only POSSIBLE CAUSES not actual problems, also when listening to your motor be very carful becuase the noise you hare from one part of the motor may actually be comming from a completely different area! its best to use a pair of engine stethoscopes from harbour freight or if your too ghetto just use a hefty sized wrench to carry the engine vibrations well
KillerR33d is offline
post #2 of 36 (permalink) Old 12-25-2006, 12:21 AM
great post. repped
post #3 of 36 (permalink) Old 12-25-2006, 06:38 AM
New to me but great post
post #4 of 36 (permalink) Old 12-25-2006, 12:35 PM
post #5 of 36 (permalink) Old 12-25-2006, 03:08 PM
REPT!
post #6 of 36 (permalink) Old 12-25-2006, 06:43 PM Thread Starter
Thanks all! i hope this will help everyone when there i diagnosing their motors, i might be a little bit optimistic here but maybe this should become a sticky?
post #7 of 36 (permalink) Old 12-25-2006, 07:52 PM
post #8 of 36 (permalink) Old 12-26-2006, 12:23 AM
great post. repped
post #9 of 36 (permalink) Old 12-26-2006, 09:50 PM
post #10 of 36 (permalink) Old 12-27-2006, 11:28 AM
well wht about when ur bike runs good till 9 grand and then its like it chocks it self and there is no more power...through all gears...cant even hit 100mph...and cant rev it past 9.5 to 10 grand so if someone knows how to fix it..let me know
SMFB636 is offline
post #11 of 36 (permalink) Old 12-28-2006, 12:26 AM
Get out the service manual.
post #12 of 36 (permalink) Old 12-28-2006, 09:46 AM Thread Starter
It could be many things happening! no compression, high leakdown etc, Did you rev the absolute be-jesus outta that motor when you got it it may contribute to a motor's early demise
Get the manual out before doing anything
post #13 of 36 (permalink) Old 12-29-2006, 12:52 AM
Nice work.
post #14 of 36 (permalink) Old 12-29-2006, 12:56 PM
sell your harley
.... but if its not a oil leaker, read the manuel or take it to a trust worthy mechanic
post #15 of 36 (permalink) Old 01-02-2007, 05:31 PM
when i bought it it had 8,500 miles and toped out at 180.....and since the butterfly exhaust valve went out it just has went down hill.......and i tried looking at the service manual and it doesnt tell me anylike whts happening....so wht should i do
SMFB636 is offline
post #16 of 36 (permalink) Old 01-10-2007, 03:48 PM Thread Starter
buttery fly valve? almost all motors have poppet valves within the engine...unless you mean the servo-controlled valve(power valve) that sits in the collector, apart from that im afraid i don't know what your going on about
post #17 of 36 (permalink) Old 01-10-2007, 03:55 PM
You're gonna get valve noises out the box from most 600's. It's what they do.
post #18 of 36 (permalink) Old 01-10-2007, 04:08 PM
My 750 makes ticking noise but I cant tell if its just normal FI noise or if the valves ticking.
post #19 of 36 (permalink) Old 01-10-2007, 04:11 PM Thread Starter
The injectors themselves do make a faint ticking noise. just grab a hefty sized wrench and have a listen...you be surprised all kinds of weird noises motors makes
post #20 of 36 (permalink) Old 01-10-2007, 04:18 PM
I'm calling bs on the whole thing, the chances of diagnosing a engine problem by noise alone is slim to none @ best.
Twisty had a tick in his TL and the dealer said it was normal. 1000miles later the cam scissor gear let loose grenading the whole motor....If the tick is not normal to you, take it to the dealer and demand it be fixed. If your turned away, call the manufacturer customer service line and report it. The dealers are very often wrong...
Also most in-lines will make a little chatter in the valves due to VVT.
Pippi is offline
