sprokets and fuel mapping? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 12 (permalink) Old 01-15-2007, 07:08 PM Thread Starter
what exactly does changing sprockets do, and what does fuel mapping do?
iceman0481 is offline
post #2 of 12 (permalink) Old 01-15-2007, 11:01 PM
changing sprockets changes the gearing on a bike, add teeth to the back or remove them from the front to lower the gearing (more grunt) , add teeth to the front and remove them from the rear raises the gearing, more top end no low end, fuel mapping changes the air/ fuel ratio amoung other things in fuel injected bikes (kinda like changing jets and needles in a carburater)
post #3 of 12 (permalink) Old 01-15-2007, 11:04 PM
Drewpy is right on. A common mod is to go -1 in the front and +2 in the back for a little more low end pop.
post #4 of 12 (permalink) Old 01-16-2007, 06:55 AM Thread Starter
i see
so how many people actually fool around with their fuel mapping? or is it just whatever you prefer
post #5 of 12 (permalink) Old 01-16-2007, 06:26 PM
You usually end up messing with the fuel mapping if you change the air box from stock, or replace the stock exhaust with a full aftermarket systems. Both of those Mods affect the air/fuel ratios so you need to refine the map to maximize the effects of your modifications.
justpucky is offline
post #6 of 12 (permalink) Old 01-16-2007, 07:29 PM
I suppose one can optimize fuel mapping on stock exhaust, stock filter and probably intake restrictor plate still in place. Stock gearing and Fuel mapping from the factory is there to make the bike pass emission test and noise test, which doesn't mean that your bike is running at optimum setting.
However, most people don't change the fuel mapping unless they do things to really change the bike's breathing such as freer flowing air filter, removing air intake restrictor plate, catalytic converter removal, exhaust system replacement, etc.
fnfalman is offline
post #7 of 12 (permalink) Old 01-16-2007, 07:31 PM
Way to go Pucky!
post #8 of 12 (permalink) Old 01-16-2007, 11:49 PM
post #9 of 12 (permalink) Old 01-17-2007, 11:54 AM Thread Starter
thank you
from now on im just gonna post lil thank you's, preciate the help fellas, thanks for the welcome, i know im gonna learn a lot around here.
post #10 of 12 (permalink) Old 01-18-2007, 03:25 AM
Don't be afraid to ask questions.
post #11 of 12 (permalink) Old 01-18-2007, 11:58 AM Thread Starter
dont be afraid to make an ass outta me when i ask a stupid one, and ill keep on askin
post #12 of 12 (permalink) Old 01-22-2007, 12:02 AM
deal!!
