Ok Wtf? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 16 (permalink) Old 01-18-2007, 06:49 PM Thread Starter
Ok Wtf?
The bike runs fine but when i slow to stop signs i hear a clicking noise only from under about 10mph decellerating at an idle i dont hear it just when im slowing down from 10 and speeding up to 19 anyone ideas.
Anthony is offline
post #2 of 16 (permalink) Old 01-18-2007, 06:53 PM
Check your tach and make sure its not just making a noise at certain RPM's. may not be the speed as much as the reverb from the engine at dif rpm's.
oh, and what kind of clicking, be a little more specific.
post #3 of 16 (permalink) Old 01-18-2007, 06:59 PM
also my key chain used to rattle at udle but once I got on the gas you couldn't hear it .... I doubt that's your problem but check it anyways...
post #4 of 16 (permalink) Old 01-18-2007, 07:07 PM Thread Starter
hmm sounds like when you hit your knuckles together cept louder sry best description i can give
Anthony is offline
post #5 of 16 (permalink) Old 01-18-2007, 07:21 PM
Are there CCT problems with the tillers?
Do you ride wheelies?
post #6 of 16 (permalink) Old 01-18-2007, 07:31 PM
your tach is electronic, if I recall correctly.
If you roll forward at 2-5 mph and tap-tap-tap the front brakes, is the noise still there?
If so, look for a loose wiring connector or your steering head bearings.
2 of my TLs suffered from loose headlight brackets, try that too.
My front race rotors were REALLY loud at low speeds, in city traffic. Are yours stock?
Also, check your chain as it is a very tight left side bend on those TL's.
Loren.
WarpedRotor is offline
post #7 of 16 (permalink) Old 01-18-2007, 08:15 PM
reason i said check the tach, is that I had some problems w/ rattling that only occured around 3-4 rpms. it turned out to be the frequency of the engine revving was just right to rattle some screws that needed to be tightened and some rubber grommets that needed to be replaced.
doesnt seem to be his problem though.
post #8 of 16 (permalink) Old 01-18-2007, 10:17 PM
does the sound increase/ decrease with speed or is it constant?
post #9 of 16 (permalink) Old 01-18-2007, 10:56 PM Thread Starter
not too sure next time i ride it ill get back to you for now imma go check all bolts n stuff make sure nothins commin loose
Anthony is offline
post #10 of 16 (permalink) Old 01-18-2007, 11:26 PM
That sucks man...
post #11 of 16 (permalink) Old 01-19-2007, 11:24 AM
Wockman's Avatar
Chain and sprocket noise? If your chain is loose it can make a clicking noise. Especially if the sprockets are worn.
Honda CBR1100XX Blackbird
Wockman is offline
post #12 of 16 (permalink) Old 01-19-2007, 11:41 AM
Start there. Where's it coming from?
post #13 of 16 (permalink) Old 01-19-2007, 01:56 PM
March 2008 BOTM Winner!
pickle.of.doom's Avatar
Clicking can be bearings as well if they are shot. Check them next time you have your wheels off.
pickle.of.doom is offline
post #14 of 16 (permalink) Old 01-19-2007, 09:06 PM
It's probably the scissor gears on the end of your cams. Does it sound like light tapping? All tillers have that sound.
serialtiller is offline
post #15 of 16 (permalink) Old 01-20-2007, 10:51 AM
Love your user name.
post #16 of 16 (permalink) Old 01-22-2007, 08:43 PM Thread Starter
think thats it ty man if it gives me problems another thread will be up
Anthony is offline
