value ajustment honda 954 rr! - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 3 (permalink) Old 01-22-2007, 11:41 AM Thread Starter
Can any one tell me a good way to move Throttle Cable for Clearance to remove head cover???????????????
Thanx
buffmale45 is offline
post #2 of 3 (permalink) Old 01-22-2007, 10:55 PM
If you are removing the head to do a valve adjustment... why don't you just remove your throttle cables from the linkage? Its not that hard... losen them up at the the grip and you should be able to pull them from the linkage. Plus it will give you a chance to lube the cables from both sides.
post #3 of 3 (permalink) Old 02-21-2007, 03:51 PM
crazy2wheeler is offline
