oil chnage and plugs - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 14 (permalink) Old 01-22-2007, 11:53 PM Thread Starter
Me n the old man put new plugs and changed the oil yesterday i will never put plugs in again, it blew balls droppin the radiator and lifting the ****in tank to put in some BS plugs where you cant reach unless you got baby hands. Btw my old plugs looked great thank you very much. Now for a chain cleaning any suggestions on a fastway to do it besides buyin a new 1 ?
Anthony is offline
post #2 of 14 (permalink) Old 01-23-2007, 12:11 AM
they have a special tool that makes cleaing a chain a simple painless ordeal, i think its the "grunge brush" gas told me about it eaerlier this year
post #3 of 14 (permalink) Old 01-23-2007, 12:18 AM Thread Starter
well i want it
Anthony is offline
post #4 of 14 (permalink) Old 01-23-2007, 02:18 AM
That or just get a toothbrush. Put something under your chain to catch the gunk that falls off. I use WD40 to clean. (Cue the debate...) Works like a charm.
post #5 of 14 (permalink) Old 01-23-2007, 10:51 AM
WD40 rocks... it also works great cleaning them white rims (don't get it on your brake rotors or tires).
post #6 of 14 (permalink) Old 01-23-2007, 04:33 PM
What chemical depends on what type of chain you have. If you have a - or x ring I suggest you stay away from wd40. Use kerosene.. like in heaters. Its a oil and therefor has some lubricity to it.
What tool? That's easy. If you're cheap... a old tooth brush and a bunch of rags. If not.. then you want "The grunge brush"
Video
post #7 of 14 (permalink) Old 01-23-2007, 04:52 PM
great find gasman ...................rept
post #8 of 14 (permalink) Old 01-23-2007, 04:59 PM
FYI, most tanks (probably on the newer bikes) have a deal where, if the tank is raised to a certain height, the bolt that holds it (by your crotch) can be used to hold the tank at that height.
post #9 of 14 (permalink) Old 01-23-2007, 05:15 PM
Thanks... I use to have one!
I have seen many with like hood props under the tanks! GSXR's I think..
post #10 of 14 (permalink) Old 01-23-2007, 05:16 PM
Mine uses the bolt technique.
post #11 of 14 (permalink) Old 01-23-2007, 05:25 PM
Yeah my 9R had nothing... it sucked!
post #12 of 14 (permalink) Old 01-23-2007, 05:41 PM
WD40 wont hurt your chain if you dont leave it on there. Use it to clean...ride around the block then lube.
Call WD40...they'll tell you too.
I wouldn't soak it in the stuff but it'll do fine to clean it. But yes, kerosene is recommended.
And I use a block of wood to hold my tank up, when reconnecting fuel lines...otherwise it's gotta come all the way off.
post #13 of 14 (permalink) Old 01-23-2007, 11:02 PM Thread Starter
roger, whole thing is i was talking to a local cop whose got a 600 and is the motor cop he was raggin on me about it i cant let it go now
Anthony is offline
post #14 of 14 (permalink) Old 01-23-2007, 11:06 PM
stomper173 is offline
