I Need Help - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 11 (permalink) Old 01-24-2007, 11:59 PM Thread Starter
I Need Help
I laid my bike down 3 weeks ago because some ******* decided to spill oil all in the street . Now my bike is leaking oil its small and its not spurting or anything but it is leaking from what i can see nothings cracked but it is still leaking. Does anyone know what the problem may be.any chance it can be fixed with out replacing the whole thing , and how much does it cost to replace , and can i do it myself or do i need to have it done at a shop I realize this maybe a simple question to some of you, but please no smart ass remarks?
RIDE THAT BITCH TILL THE WHEELS FALL OFF!!!!!!
jaisan72980 is offline
post #2 of 11 (permalink) Old 01-25-2007, 12:00 AM
Where is it leaking from? Bike make and model?
post #3 of 11 (permalink) Old 01-25-2007, 12:04 AM Thread Starter
07 gsxr 600 left side its definetly oil
post #4 of 11 (permalink) Old 01-25-2007, 12:06 AM
Coming from the stator cover is my guess. Can you post a pic?
post #5 of 11 (permalink) Old 01-25-2007, 12:17 AM Thread Starter
here is the link
http://new.photos.yahoo.com/jaisan72...60762386814880
post #6 of 11 (permalink) Old 01-25-2007, 12:22 AM
I can't see oil there...is it leaking from the case there? Did the slide wear through the metal?
If that's the problem you can fix that yourself. Get a service manual if you dont already have one. You'll need the part and a gasket at the very least....and maybe some bolts if you scraped some of them down.
post #7 of 11 (permalink) Old 01-25-2007, 12:25 AM Thread Starter
no the leak is on the bottom side , do u kno where i can get the part cheap???
post #8 of 11 (permalink) Old 01-25-2007, 12:27 AM
eBay would be the first place I look. If nothing there then try a salvage yard or ronayers.com.
Have you tried re-torqueing the bolts?
post #9 of 11 (permalink) Old 01-25-2007, 07:18 PM
Man... you need a new stator cover and gasket!
It sucks... did a ebay search... HERE
Here's a stocky one for $130
And For $290 you can get a custom one.
Just make sure you get from ebay or the dealer...the new gasket. Its usually a ordered item. You might get by with a some silicone but I wouldn't chance it.
Which reminds me... get some gray colored high temp silicone. You will most likely need to put some on the gasket to keep it from leaking oil.
Further, when you go to pull the cover it may seem to stick on... no worries... that is the magnets from the stator (MC version of a alternator) but this should be a problem sense it appears to be alum and not magnesium like some others.
post #10 of 11 (permalink) Old 01-30-2007, 11:09 PM
ah
same **** that happened to my bike.
You will need a new water pump. talk to the techs at the dealer.. if your lucky they will warrenty every thing like they did for me.
it looks like it is comming from the back of the water pump? on the pump shaft yes?
If u look closely looks like it's coming out of the peep hole on the water pump, it seems it's faulty in alot of the 07 gsxr's.. just when you take it in.. and they will work on it under warrenty have them order a water pump, before they do any thing else.. trust me :p
https://www.twowheelforum.com/showthread.php?t=14171
check that post
cloner_357 is offline
post #11 of 11 (permalink) Old 01-31-2007, 07:10 AM
that still don't chage the fact that he has a rashed cover!
And remember... on most of these bikes... your oil pump and water pump are driven off the same input shaft.
