need help diagnosing - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 12 (permalink) Old 02-08-2007, 01:26 AM Thread Starter
95 RF900r sometimes when the bike sits 4 a couple of days and i fire it up,it has a dead miss and it pops out of the exhaust.If i let it warm up,or ride it 4 a while it smooths out and runs great.Yesterday it took about 12 miles for it to smooth out.My thinking is a sticky valve,but i really don't know what the hell i'm doing.My last bike didn't require valve jobs.I've only had this bike 1 month so i don't know when the last valve job was done.Thnx in advance!
rickyhj2002 is offline
post #2 of 12 (permalink) Old 02-08-2007, 02:06 AM
First off how many miles...
Second, have you checked the spark plugs...
post #3 of 12 (permalink) Old 02-08-2007, 02:15 AM Thread Starter
13,000miles new plugs(NGK)
post #4 of 12 (permalink) Old 02-08-2007, 12:42 PM
how about plug wires? they too can be defective.
post #5 of 12 (permalink) Old 02-08-2007, 01:37 PM
Wockman's Avatar
+1 on the plug wires.
Did it do it before you changed the plugs? Are they gapped correctly?
Honda CBR1100XX Blackbird
Wockman is offline
post #6 of 12 (permalink) Old 02-08-2007, 06:45 PM
rickmancc's Avatar
wires and check ur air filter
rickmancc is offline
post #7 of 12 (permalink) Old 02-09-2007, 12:38 AM
When Gasman asks if you checked the plugs, he means if you checked them for fouling, incorrect gaps, correct type, and any differences in color. Also, is the poor running at idle, high rpm, or all over?
post #8 of 12 (permalink) Old 02-09-2007, 01:02 AM
Yes sir NW.
Always start with the basics. Don't assume just cause you just replaced them that they are fine.
post #9 of 12 (permalink) Old 02-09-2007, 01:05 AM Thread Starter
Thnx guys.........guess i need to focus a little more on the wires,plugs and check the air filter.Did find out the wires are made into the coils and they're $75 acoil.I'll keep checkin' those things,maybe somethin will turn up.BTW its allover not just at idle.
post #10 of 12 (permalink) Old 02-09-2007, 11:48 AM
If you had to ride 12 miles to get it to smooth out then you probably have alot of gas washing down your cylinder walls into your oil thinning it out. Not a good idea, keep an eye on your oil level!
mlkx3 is offline
post #11 of 12 (permalink) Old 02-12-2007, 02:11 AM Thread Starter
Thnx 4 the help.Turns out the plugs weren't gapped correctly.smooth&strong now!
post #12 of 12 (permalink) Old 02-12-2007, 04:49 AM
Look at that.
