Mapping Pricing - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 23 (permalink) Old 03-02-2007, 09:59 AM Thread Starter
Mapping Pricing
Hey ya'll, thinking about getting my bike mapped. Anyone know approx. how much this is?
rockinthef4i is offline
post #2 of 23 (permalink) Old 03-02-2007, 12:19 PM
check around...different pricing
post #3 of 23 (permalink) Old 03-02-2007, 12:22 PM
lol, great answer.
Its gonna be much more expensive to do it at a dealer. try to find a local shop that has the equipment, and just call around. Its hard for us to give you a price because this is really a local thing.
post #4 of 23 (permalink) Old 03-02-2007, 12:39 PM
lol, great answer.
did you like that answer? a lil more smart ass then I was trying to be...my bad...
post #5 of 23 (permalink) Old 03-02-2007, 12:50 PM
I had a TRE and custom map done for $180. Thats as low as I could find...
dim_sum is offline
post #6 of 23 (permalink) Old 03-02-2007, 01:50 PM
if you have the money just get a powercommander. if not then call around to shops around your area and think about the distance you wouldn't mind going to get there.
busafied is offline
post #7 of 23 (permalink) Old 03-02-2007, 02:34 PM
pc isnt going to really help him, or when you buy it do they map your bike for free?
post #8 of 23 (permalink) Old 03-02-2007, 03:20 PM
pc can help help him...you should get a cd with it and on the cd it has all bikes with most of they set-up they can think of...find one thats most identical with you bike and your set...wont be fine tuned but its a rough map best suited to what you have!
KillerR33d is offline
post #9 of 23 (permalink) Old 03-02-2007, 03:24 PM
sounds good...
YZFR61ST is offline
post #10 of 23 (permalink) Old 03-02-2007, 04:02 PM Thread Starter
i've heard that is really doesn't help getting a power commander if you get a slip on exhaust; supposedly if you have one or the other it will do the same thing? Or is that just some bs?
post #11 of 23 (permalink) Old 03-02-2007, 04:03 PM
it wont help AS MUCH, thats all. it will only make a noticable dif if you get a full system.
post #12 of 23 (permalink) Old 03-02-2007, 04:08 PM Thread Starter
oh ok. I have a D&D slip on and I noticed a little change in torque and acceleration from the stock on. Does adding a PC make a noticeable change or is it subtle?
post #13 of 23 (permalink) Old 03-02-2007, 04:53 PM
not w/ your slip-on, surprised you could actually feel the dif w/ a D&D
post #14 of 23 (permalink) Old 03-02-2007, 04:59 PM
oop, I sense a classic D&D bash session...
CB1terror is offline
post #15 of 23 (permalink) Old 03-02-2007, 05:16 PM Thread Starter
yeah i felt the change. i guess that's what happens when you buy a good exhaust set.
post #16 of 23 (permalink) Old 03-02-2007, 05:18 PM Thread Starter
oh by the way, could you type a little bit bigger, i'm dizzy from the sound of my D&D, so i can't see as well. thanks
post #17 of 23 (permalink) Old 03-02-2007, 05:39 PM
lol i was in no way bashing D&D, i was thinking about picking one up myself. should have just said i'm surprised you noticed so much change with ANY slip on. must have really done your bike a favor.
post #18 of 23 (permalink) Old 03-02-2007, 07:37 PM
I gained 7 ponies by advancing the timing and getting her custom mapped...
dim_sum is offline
post #19 of 23 (permalink) Old 03-02-2007, 09:00 PM
the PC just smooths out the power curve for the most part. with some nice side effects. you will notice the difference if you get the fuel pump accelerator and the right map installed.
post #20 of 23 (permalink) Old 03-02-2007, 11:17 PM
Louder always seems like it's faster. But most pipes make a bike slower. Yeah, yeah, I know about the weight savings. If I had a fuel injected bike, the first thing I would do is synchronize the injectors. Then I would get a dyno run to see how the bike is running. They charge $50 for a baseline run in my area. Just remember that dyno runs are done at wide-open throttle. If you have a stumble off idle when pulling from a stop, or part-throttle problems, it won't register on the dyno sheet.
