Should I worry about this? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 15 (permalink) Old 03-24-2007, 11:42 PM Thread Starter
I was take'n my bike apart to change my signals and to get it ready for painting... I decided to check the coolant and found what looked like crystals in it... though I'm not sure if it's metallic or not.
you can barely see it in the coolant here
and on the rubber gasket
this coolant has sat in the bike over my deployment and the winter... so over a year...
So... is it something to worry about?
post #2 of 15 (permalink) Old 03-24-2007, 11:44 PM
I don't know man....I would get it flushed to make sure.
post #3 of 15 (permalink) Old 03-24-2007, 11:44 PM
i see them all the time in cars.. nothing to worry about, if it makes you feel better, just flush the whole system. now if there was oil, or chunks of sludge.. then id worry
cloner_357 is offline
post #4 of 15 (permalink) Old 03-24-2007, 11:49 PM Thread Starter
Cool... yeah I think I've gotta take the radiator off anyways to put on my headers... so I guess it's not TOO big a deal... just wanted to make sure it wasn't anything really horrible...
post #5 of 15 (permalink) Old 03-24-2007, 11:50 PM
Possible that it gelled up in that coldass Alaska winter. I'd replace it.
post #6 of 15 (permalink) Old 03-25-2007, 09:22 AM
probably nothing to worry about, but if it makes you feel better, flush it. its all about having peace of mind.
post #7 of 15 (permalink) Old 03-25-2007, 09:37 AM
I trust you got new exhaust gaskets to go with those headers, eh ebbs?
post #8 of 15 (permalink) Old 03-25-2007, 11:51 AM
Ebbs... none of your pics work!
post #9 of 15 (permalink) Old 03-25-2007, 12:24 PM
worked yesterday
post #10 of 15 (permalink) Old 03-25-2007, 01:36 PM Thread Starter
no i was a thinking they'd come with some... but yeah no way i was gonna re-use the old ones...
the gaskets can't be that much and they'd definitely be worth the peace of mind
post #11 of 15 (permalink) Old 03-25-2007, 01:37 PM Thread Starter
should work now... fixed the links
post #12 of 15 (permalink) Old 03-25-2007, 06:19 PM
Looks like calcium deposits, similar that you will find in your hot water heater at home. No big deal, but I would flush it out. Also, use distilled or softened water to dilute the coolant to prevent any more scale from building up.
6doublefive321 is offline
post #13 of 15 (permalink) Old 03-25-2007, 08:11 PM
Gelled antifreeze is no joke. Had a car gel up after a couple years sitting. Instant over-heat whenever we started it. It started first time and every time, but that chit was blocking the thermostat. Zero circulation. Had to drain and flush the system several times.
post #14 of 15 (permalink) Old 03-25-2007, 10:21 PM
Flush that thing out!!
Use ONLY distilled water. Its cheap. Buy like a 2 gal container for like $3. Flush it out like 3 times! You can read some of my recent postings on flushing to find out how I suggest doing it. Its real easy it just takes some time.
Then just run Engine Ice! Get 2 1/2 gal jugs of that.
post #15 of 15 (permalink) Old 03-26-2007, 12:10 AM Thread Starter
Cool Cool... yeah I was gonna flush it anyways... it seemed to want to over heat when ever I was in heavy traffic up here... yet the temp was in mid 50's! so something was up...
thanks guys!
