SV Fork/damper rod problem - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 11 (permalink) Old 03-25-2007, 05:05 PM Thread Starter
Exclamation SV Fork/damper rod problem
Alright this could potentially take more thought and technical knowledge than 99.9% of the questions posted by most people (myself included) in this tech forum, so get your thinking caps on:
The bike is a mostly stock '01 SVS. So I'm in the middle of putting new springs, oil, and emulators into my forks. One fork went with no issues and is back together awaiting the first test ride. The other fork is giving us some trouble. With no damper rod inside the tubes slide smoothly and easily just like they should, there is no sign of anything bent or out of place. Then when we put the damper rod and top-out spring in and get the bolt started into it the fork tubes won't slide apart. Thus the damper rod is catching on some internal fork part and we can't figure out how to get it to work. With the fork fully extended the damper rod is caught in the middle, but the working fork did the same thing and all we had to do was compress the tubes, get the bolt started into the damper rod and then extend the tubes. After trying a few times to get the problematic one to work we dumped the damper rod and top-out spring out of the fork, to our surprise a very small light-duty spring also fell out and it doesn't appear on any parts fiches or manuals...has anyone run into this problem? Any advice? I should have a picture of the small spring soon if anyone cares to see it.
Knight is offline
post #2 of 11 (permalink) Old 03-25-2007, 07:14 PM
Have you should posted up on svrider? Some of the first gen guys are pretty knowledgable over there.
post #3 of 11 (permalink) Old 03-25-2007, 07:16 PM Thread Starter
yeah I posted this at svrider, cf, wera, wos, etc; all the usual suspects. I didn't expect to get much help from here but thought it was worth a shot
Knight is offline
post #4 of 11 (permalink) Old 03-25-2007, 07:25 PM
Hope you figure it out, the upgrade is well worth it. That's weird about that other spring.
post #5 of 11 (permalink) Old 03-25-2007, 10:13 PM
Man...thinking caps nothing... that is a bit complicated for me to even think about over the internet. I'm not that good with suspension. Maybe if it was in front of me... MAYBE! Knight.
post #6 of 11 (permalink) Old 03-25-2007, 10:14 PM
The damper rod in my 79 Suzuki has a small spring on the bottom, like this diagram of a SV: http://www.ronayers.com/fiche/300_03...0&parent=11810.
post #7 of 11 (permalink) Old 03-25-2007, 10:16 PM
GREAT CALL NW!!! REPT! Which took you to your first goldie!
post #8 of 11 (permalink) Old 03-25-2007, 10:47 PM Thread Starter
The manual/ron ayers is the first place I looked and this spring is not on the parts fiche...which is also perplexing. The spring is smaller than the diameter of the damper rod and thus the rest of the fork tube. I think the spring you're talking about is what I call the top-out spring which is a small (maybe 2") spring that is at the bottom of the damper rod.
Knight is offline
post #9 of 11 (permalink) Old 03-26-2007, 01:42 AM
Hit Super up Knight, I'm sure he should be able to help out.
Pippi is offline
post #10 of 11 (permalink) Old 03-26-2007, 10:51 AM Thread Starter
Good idea Pippi. I might call him tonight. Though I think we're getting a little closer to figuring it out thanks to the MI guys on CycleForums and guys on WERA's board. It is likely a spring from the bottoming cone at the base of the fork. Here's a picture of it.
So hopefully fixing/removing the bottoming cone will take care of the problems. Keep your fingers crossed for me!
Knight is offline
post #11 of 11 (permalink) Old 03-26-2007, 05:38 PM
Yeah... this is what we call a normal day in wrenching paradise. Nothing goes as planned.
