Clean carbs on '96 YZF600 - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 30 (permalink) Old 04-02-2007, 02:24 PM Thread Starter
sdog30's Avatar
Hey guys,
So the YZF I just picked up needs to have the carbs cleaned. I don't feel like spending the money to have the dealer do it, but when I took everything apart to get to them, I wasn't quite sure how unbolt the carbs from the engine. There are some allen bolts holding it on, but the bolts towards the front of the bike are impossible to get to. Anybody have any experience with this? I looked through the manual thread, but couldn't find my exact bike. Thanks.
"Professor, what's another word for pirate treasure?"
sdog30 is offline
post #2 of 30 (permalink) Old 04-02-2007, 02:48 PM
Originally Posted by sdog30 View Post
Hey guys,
you might call and ask a local shop... sometimes (depending on the person) they may give you a little advice or tips/tricks... but not everyone will...
that being said... I have no ****ing idea!
post #3 of 30 (permalink) Old 04-02-2007, 03:26 PM Thread Starter
sdog30's Avatar
Thanks EBBS...for nothing! (j/k)
I'm looking at $250 to have the shop do it and might just end up going that route. Kind of sucks though. It's basically just taking it all apart, cleaning it with parts wash and then putting back together. I can do that. Just no clue on how the carb comes off. There's four of them, too. You'd think you could buy a Haynes or Chilton repair manual at the dealer like you can with a car at Auto Zone, I still have to look online.
Just thought someone might know. Maybe I'll post in the Yami section.
sdog30 is offline
post #4 of 30 (permalink) Old 04-02-2007, 03:30 PM
the mods will probably move it there anyhow so don't worry about it
yeah I've seen Chiltons or was it haynes for motorcycles... don't remember where though... but GOOGLE is your best friend
try calling the shop and asking... you may luck out!
oh and yeah my ex-girlfriend pretty much agrees... I'm good for nothing
post #5 of 30 (permalink) Old 04-02-2007, 03:52 PM
That and adjusting carbs can be tricky. Especially that syncing of all 4 carbs.
777Customs is offline
post #6 of 30 (permalink) Old 04-02-2007, 05:29 PM Thread Starter
sdog30's Avatar
It pisses me off, because if my friend (the previous owner) had just spent the $2.50 on gas restore and added it before winter, this wouldn't even be an issue.
Well for the input. Anyone else who's done it, give me a shout.
MODS: you can move this thread into the Yamaha section if that's a more appropriate place for it. I wasn't sure.
sdog30 is offline
post #7 of 30 (permalink) Old 04-02-2007, 06:53 PM
Hey guys,
Congrats on trying to do it yourself. Haynes manuals have good instructions and pictures on how to take off, clean, and install carbs. If they are bolts, can you get a small wrench on the side of them?
post #8 of 30 (permalink) Old 04-02-2007, 07:06 PM
post #9 of 30 (permalink) Old 04-02-2007, 11:39 PM Thread Starter
sdog30's Avatar
Yeah, I've used them for cars I've owned and they pretty much tell you step by step. The bolts are allen head. The ones on the gas tank side are easy to get to, but the front side bolts are coverd by the frame and the tree. Thanks, though.
Hey Ebbs, thanks for the link. I did a little digging around and found the Haynes book on sale at discountautorepairmanuals.com
Seems to be the cheapest price I've found. Good looking out, though.
Could still use input from people who have done it while I'm waiting for the book. Thanks.
sdog30 is offline
post #10 of 30 (permalink) Old 04-03-2007, 08:20 AM
I got a manual right from Yamaha which is the actual service manual the dealers use for my 95 YZF600. Cost like 60 bucks but has been worth it as I've totally torn my engine apart using it.... I don't remember too much of an issue getting my carbs off... I will check the manual tonight when I get home and let you know if I see anything though.
oldman2007 is offline
post #11 of 30 (permalink) Old 04-03-2007, 10:58 AM Thread Starter
sdog30's Avatar
Thanks, man.
I've taken the gas tank off, then the air box, then there are four carbs connected together with an aluminum bar that goes across all four on the tank side. The plastic stacks on the top of each intake are easy to remove because its just two screws on top of each one. I get lost after that, though. It looks like each carb is attached by an allen bolt in the front and one in the rear. It didn't look like I could access the rear bolts, so I didn't go any further. I wasn't sure if I had to remove something else to get to those or not.
I thought about ordering the Yamaha service manual, but wnated to save the extra $40 and thought the Haynes would be in layman terms and instructions.
sdog30 is offline
post #12 of 30 (permalink) Old 04-03-2007, 11:39 AM
Are you taking each carb apart from each other to get them off? They usually come off as all four together and should stay together during the cleaning process. Hose-type clamps usually hold the carb outlets to the inlets of the intake manifold (cylinder head).
post #13 of 30 (permalink) Old 04-03-2007, 12:06 PM Thread Starter
sdog30's Avatar
No, I wanted to take the four off as a group, but I was just asking if I had to take them apart to get them off. There was hose clamps attaching the air box to each plastic stack coming off the intakes, but I didn't see anything like that under the carbs. I'll check today after work, maybe I missed them. It just looked like they were individually bolted on the cylinder head with the allen bolts. I'll definitely check that out, though. Thanks.
sdog30 is offline
post #14 of 30 (permalink) Old 04-03-2007, 01:35 PM
No prob... that's why I'm here... well that and to RaeRR
post #15 of 30 (permalink) Old 04-03-2007, 03:03 PM Thread Starter
sdog30's Avatar
DUDE...who's not hear for that?
Even Nee is all over her.
Actually....that gives me an idea...
sdog30 is offline
post #16 of 30 (permalink) Old 04-03-2007, 03:33 PM
where is Rae anyhow?
post #17 of 30 (permalink) Old 04-03-2007, 04:46 PM Thread Starter
sdog30's Avatar
I don't know...I've been kind of MIA myself for the last several months. Hard to think about bikes when there's snow on the ground, but I suppose I don't need to tell you about that.
sdog30 is offline
post #18 of 30 (permalink) Old 04-03-2007, 06:29 PM
That's why I'm on here now. Think I'm going to waste precious riding time on here talking to you losers!?!
J/K
post #19 of 30 (permalink) Old 04-04-2007, 10:14 AM
Well my computer died at home and I forgot all about bringing the manual to check.. Computer will be fixed tonight.
Each carb has bolts that hold it on but by leaving the bar across the side they all come off together. You might be able to look at the parts ordering manual off a website and figure it out. They have exploded views of the different components. Won't tell you how to take it off but you may be able to see. Here is one website that has the parts overviews I'm talking about... www.yamahasportsplaza.com there are many more like it but this one is mine.... sorry couldn't resist the full metal jacket comment.....
Slap me around hopefully I'll remember to look for you tonight.
post #20 of 30 (permalink) Old 04-04-2007, 11:16 AM Thread Starter
sdog30's Avatar
Hey man, you're right. I looked last night and there are hose clamps that attach them that are accessible from the side. It was dark, so I couldn't really see what head it is, but it looks like a small allen. Thanks for the suggestion.
Hey oldman2007,
If you think of it and have the time, maybe you can scan in the pages for carb cleaning and PM me. I'm ordering the Haynes book, but I don't think it'll be here by this weekend. Just want make sure I'm not taking something off I don't need to and shouldn't.
sdog30 is offline
