flushing brakes ??? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 13 (permalink) Old 04-08-2007, 09:31 AM Thread Starter
flushing brakes ???
Getting bike ready for the next track day, May 18th, and doing what the tech guy told me to do before next time. I replaced front brake pads, (I can not believe I paid a shop to do that before ) now I want to flush my system.
do I do one side at a time? I.E. loosen one bleeder nut engage brake lever till resavore is emptey. ad new fluid until clean coming out (old fluid is dark brown)and until line is free of air ect. secure bleeder nut and repeat for other side?
thanks for the help
anyexcus2ride is offline
post #2 of 13 (permalink) Old 04-08-2007, 09:47 AM
Try to avoid air in the line, it makes it much easier to flush than to bleed. I'd use a syring or turkey baster, get the old fluid out of the resevoir without opening any bleeder valves if you can, wipe it out good to clean out any contaminants in the old fluid.
Then yes, just put the new fluid in the resevoir, and as you bleed one line at a time, watch for the new fluid to flow out, you will definately notice the color change in in your bleed line. Watch the resevoir and make sure that it doesn't get empty and let air into the line.
justpucky is offline
post #3 of 13 (permalink) Old 04-08-2007, 09:50 AM Thread Starter
thanks pucky
post #4 of 13 (permalink) Old 04-08-2007, 09:51 AM Thread Starter
How am I going to get the turkey baster out of the kitchen and into the garage...? This would seem the most challenging at this point. LOL
post #5 of 13 (permalink) Old 04-08-2007, 10:56 AM
According to OTB, your better off buying your own, and labeling "GARAGE" Apparently it is NOT good for the marriage to take it out of the kitchen, then return it. He seemed to be speaking from experience on that post.
post #6 of 13 (permalink) Old 04-08-2007, 12:08 PM Thread Starter
I will take that as solid advice Off to the dollar store I go
post #7 of 13 (permalink) Old 04-08-2007, 12:20 PM
yup. thats how I do it. works out perfectly. Pucky, excellent explanation of how to do it.
post #8 of 13 (permalink) Old 04-09-2007, 01:23 AM
Yeah... and while you're flushing... make sure you don't let the resevoir run dry and put air in it!!! THis is very important!!!
post #9 of 13 (permalink) Old 04-10-2007, 03:36 PM
rworkman98's Avatar
100%. I've done this on my bike this way, and it's pretty easy. You don't need a turkey baster. The resivour isn't that big anyway. Just put the new fluid on top of the old, and make sure you keep topping it off so you don't get any air in the line.
2005 GTO IBM/Blue/MN6
1998 Kawasaki ZX-9R
1982 Datsun 720
rworkman98 is offline
post #10 of 13 (permalink) Old 04-11-2007, 01:33 AM
Thats what I do. You'll know when the new stuff gets through.
post #11 of 13 (permalink) Old 04-11-2007, 09:17 AM Thread Starter
I ended up getting a call from my brother in-law and he had me come by his work (tech for local ford store) and let me use a bleeding/flushing machine. I was pretty cool. sucktion hose hooked right up to bleeding nut and ran the resavoir through twice. no fluid all over the place
post #12 of 13 (permalink) Old 04-11-2007, 03:52 PM
Don't do that... if not a turkey baster then just use a rag.
post #13 of 13 (permalink) Old 04-11-2007, 04:45 PM
but I've never used a bleeding device and I've never gotten a drop of fluid anywhere it wasn't supposed to be.
