Gas tank Leaking Fuel? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 7 (permalink) Old 04-14-2007, 03:47 AM Thread Starter
I need some help as I'm scratching my head on this one. I finally rebuilt my engine after 2 years of sitting torn apart. The gas tank and fuel pump were fine for 2 years when I emptied the old fuel and put new fuel in, it started flowing from the fuel pump. No power was connected so it shouldn't have been doing anything and I'm confused because it had fuel in it before and never leaked.
Any ideas?
Btw it's a 95 YZF600R
oldman2007 is offline
post #2 of 7 (permalink) Old 04-14-2007, 09:30 AM
not sure how the setup is on those bikes. I know theyre not injected, i thought they were gravity fed like the f2's but if you have a pump guess not...
Is the petcock in the off position? if your petcock is on on or reserve theres your problem, easy mistake. might have been on and not had enough gas in before to leak out ???
HiLi_Psyclez is offline
post #3 of 7 (permalink) Old 04-15-2007, 12:56 AM
Does it have a petcock?
If so it most likely isn't FI and therefor it shouldn't have a pump in it?
Another way to check...
Is there a compartment at the bottom rear of the tank? A plate that unbolts for access to a fuel pump? If not... no pump!
post #4 of 7 (permalink) Old 04-16-2007, 09:07 AM Thread Starter
It does not have a petcock. It does have a fuel pump and it isn't supposed to pump (release) any fuel unless there is power to it. The tank sat for 2 years on the floor of my garage w/o leaking a drop. When I replaced the gas to start it after rebuilding the engine is when it started leaking.
People have said that as long as the floats in the carbs are working it shouldn't matter if it leaks the carbs will regulate it... It does bother me a little as to why it's doing it but I priced out a new fuel pump etc and it's over 500 bucks so I'm inclined to let it go.
post #5 of 7 (permalink) Old 04-16-2007, 09:11 AM
Are you sure there is a fuel pump?
Carbs don't use fuel pumps on bikes...
post #6 of 7 (permalink) Old 04-16-2007, 09:47 AM Thread Starter
yes I'm positive there is a fuel pump.
http://houseofmotorcycles.bikebandit...e~YZF600RG.asp
post #7 of 7 (permalink) Old 04-16-2007, 11:26 AM
Well looky there... didn't know they ran a pump on those older bikes... who would have tunk... learn somin new...
