best switch on sprokets? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 21 (permalink) Old 04-18-2007, 09:58 PM Thread Starter
Looking for the best change in teeth for front and rear. I have an '05 R6. Looking to be able to get more low and mid power, easier to pull it up in 2nd??
gparz74 is offline
post #2 of 21 (permalink) Old 04-18-2007, 10:01 PM
-1 front +1 rear..other than that it may not fit...
Brizz is offline
post #3 of 21 (permalink) Old 04-18-2007, 11:04 PM
-1F +2 rear is the most common and best all around change.
However when ever replacing sprockets you need to replace the chain. All three should be done at the same time. Further, you won't be able to get the stock chain on a + anything in the rear anyway!
post #4 of 21 (permalink) Old 04-18-2007, 11:09 PM
Well that year R6 isnt designed to do a really big sprocket in the rear. It is reccomended that the one i suggested it the best one for that bike.
Brizz is offline
post #5 of 21 (permalink) Old 04-18-2007, 11:16 PM
Really... what restrictions would the bike have on going up 2 in the rear?
post #6 of 21 (permalink) Old 04-18-2007, 11:18 PM
The swingarm dont support it.
Brizz is offline
post #7 of 21 (permalink) Old 04-18-2007, 11:19 PM
Like clearance issues?
Cause if that's the case that sucks. You really can't go down more than -1 in the front for you risk the chain binding.
post #8 of 21 (permalink) Old 04-18-2007, 11:21 PM
Im not sure..Im not a mechanic...But a mechanic friend of mine who did an 06 R6 for me says it wont work properly...
Brizz is offline
post #9 of 21 (permalink) Old 04-19-2007, 12:18 AM
diffrent bikes the 05 r6 is now the r6s
post #10 of 21 (permalink) Old 04-19-2007, 07:56 AM
I knew there was something i was overlooking....Yes you can do a +2 on the rear of that one provided you have enough chain. THX for that pick up...
Brizz is offline
post #11 of 21 (permalink) Old 04-19-2007, 08:13 AM
So you can +2 in the rear?
post #12 of 21 (permalink) Old 04-19-2007, 08:52 PM Thread Starter
so -1f +2r sounds the way to go. The new chain I figured on so no biggie there. How much power is this gonna add on the low end? Is the front well gonna want to come up in first alot quicker? i am guessing I am gonna have to change my riding style a bit..
gparz74 is offline
post #13 of 21 (permalink) Old 04-20-2007, 04:16 PM
It will be a VERY noticeable change in power. Now understand..your motor isn't making anymore power. You're just changing the gear ratio. You will have to shift gears more often because the final drive ratios will be different. You'll also loose top end speed. About 10-20mph
post #14 of 21 (permalink) Old 04-20-2007, 08:04 PM Thread Starter
I'm good w/ only going 145-150. not really safe in jersey for that anyway. Especially after racing home from the hawks nest at 155mph last yr and seeing my buddy in front of me almost get clipped at that speed. Changing gears quicker huh not much to first gear anyway but i will get use to it eventually.
gparz74 is offline
post #15 of 21 (permalink) Old 04-23-2007, 09:09 AM
Yeah you get use to it... I did that on my last chain/sprocket change on my 9R and I loved it! -1F +2R Get a DiD x-ring chain & renthol sprockets!!
post #16 of 21 (permalink) Old 04-23-2007, 11:01 PM Thread Starter
thanks gs man. do i need a speddohealer?
gparz74 is offline
post #17 of 21 (permalink) Old 04-24-2007, 03:31 PM
yes. otherwise your speedo will read higher than you're going.
post #18 of 21 (permalink) Old 04-25-2007, 11:22 AM
Oh yeah... every bike needs a speedo healer! They are up to 10% off from the factory.
post #19 of 21 (permalink) Old 04-25-2007, 09:01 PM Thread Starter
10% really? those bastards
gparz74 is offline
post #20 of 21 (permalink) Old 04-25-2007, 10:54 PM
just think, your 10,000 miles would only be really 9,000, imagine the diffrence when u go to sell it or other
