Replacing levers...any special tools or tricks??? - TwoWheelForum: Motorcycle and Sportbike forums
post #1 of 7 (permalink) Old 04-20-2007, 10:52 AM Thread Starter
I broke my clutch lever so i'm replacing both the clutch and the brake levers with colored stock replacements.....anything i should know guys?
anything i should wrry about as far as the clutch and brake cables?
i have and K7 gsxr 750.....
sv-ridin-a-sv is offline
post #2 of 7 (permalink) Old 04-20-2007, 10:56 AM
I've replaced the brake lever on my SV and it was just a matter of unscrewing it, sliding it off, replacing, bolting back, and done. Don't know about clutch side.
post #3 of 7 (permalink) Old 04-20-2007, 11:01 AM
I've replaced both on my sv, like trip said, just unscrew and replace.
Remember to lube the bolt that it piviots on, otherwise it may bind at an inopportune time.
post #4 of 7 (permalink) Old 04-20-2007, 04:45 PM
Yeah lube that clutch cable alot! LIke remove the lever, lube it, start the brake lever job, lube it some more, finish the brake lever, lube it more, finish the clutch. You can't lube it too much.
post #5 of 7 (permalink) Old 04-20-2007, 06:22 PM
you ...are a lil lube happy....
but what they said...it is an easy job.
post #6 of 7 (permalink) Old 04-20-2007, 08:31 PM
If you can figure how to get it off, it's easy to get back on.
post #7 of 7 (permalink) Old 04-20-2007, 09:30 PM
no tricks, just lube as said above. I like to wet the pivot bolts with some DuPont teflon lube as well. good stuff.
& welcome (i dont think ive dont that yet)
